Weight distribution hitch - Chevy and GMC Duramax Diesel Forum
Old 12-26-2012, 09:35 AM   eBay Motors  #1 (permalink)
I have a 2500 diesel, pulling a 36' travel trailer with a hitch weight of 850 lbs. On the drop the weight drops my rear 1-1/2". I have a sway control bar, but do I need to use a weight distribution hitch? What is the added addvatage? Thank you for your insight!
supermike78 is offline   Reply With Quote
Old 12-26-2012, 09:42 AM   eBay Motors  #2 (permalink)
MHDMAX66's Avatar
If your trailer weighs more then 8 thousand pounds I would say it would be a good idea for a wdh. It spreads the tongue weight out between the axels so the trailer isn't just slamming on the hitch.
MHDMAX66 is offline   Reply With Quote
Old 12-26-2012, 10:17 AM   eBay Motors  #3 (permalink)
nmeyer414's Avatar
Not only that but it will give you a smoother ride. (Less bouncing up and down of the rear end)
NATE
06 LBZ, CC SB
52 gal titan
edge juice w/ attitude
nmeyer414 is offline   Reply With Quote
Old 12-26-2012, 10:20 AM   eBay Motors  #4 (permalink)
anthonyshaw's Avatar
I still run mine on my 32' trailer behind my 2500hd... barely drops the rear bumper, but can tell a difference in the ride with it vs not with it
'08 GMC Sierra SLT CCSB LMM
4" MBRP Downpipe-back, EFI-Live V2, DSP5 Switch, Tuning by Idaho-Rob, EGR Block-off
anthonyshaw is offline   Reply With Quote
Old 12-26-2012, 10:34 AM   eBay Motors  #5 (permalink)
chevor's Avatar
I personally dont like how far most of the brands set the ball away from the bumper. I think theyre ok if your going to pull once and awhile. For every day pulling its money well spent to add more rear suspension to the truck, airbags, bigger springs. And upgrade receiver hitch to a heavier model.
chevor is online now   Reply With Quote
Old 12-26-2012, 11:50 AM   eBay Motors  #6 (permalink)
premis's Avatar
36' foot TAG trailer
Are you still using the stock hitch receiver? If so, I would upgrade that with so much weight on it. As for the WD hitch, you don't NEED it, but it does smooth out the ride and is worth the money. you absolutely need to do one of the two, either a new hitch receiver or a WD set-up. Not a bad idea to do both.
2005 Black Duramax Crew Cab Short Box
Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's
premis is offline   Reply With Quote
Old 12-26-2012, 01:24 PM   eBay Motors  #7 (permalink)
Super Moderator
jc1843's Avatar
Good idea to upgrade-! The stock hitch is only rated 7500 lbs-. Read the sticker on the hitch.
