Towing gooseneck with shortbed help please! - Chevy and GMC Duramax Diesel Forum
Old 01-01-2013, 05:24 PM   eBay Motors  #1 (permalink)
I have an 04 ext. cab short bed and a toolbox in the front, I'm looking to buy a gooseneck racecar trailer. I was wondering what the best way to avoid trouble as far as the trailer hitting the truck is while turning and going up a grade would be?
pjbrenneman107 is offline   Reply With Quote
Old 01-01-2013, 05:51 PM   eBay Motors  #2 (permalink)
justavillain's Avatar
B&w turn over ball and it has a 2" of set ball and maybe a 4"
More so for weight but will help I tow with a 11 ccsb with a tool box and have no problems
Sent from my Galaxy Nexus using AutoGuide.Com Free App
2011 Duramax LML, CCSB
H&S Mini Maxx
MBRP 4" Turbo back exhaust(DPF Delete)
aFe Intake system dry filter
Ranch Hand Legend Grille Guard
parking assist sensor delete
275/70r18 Nitto Terra Grappler
Cognito leveling keys
justavillain is offline   Reply With Quote
Old 01-01-2013, 05:54 PM   eBay Motors  #3 (permalink)
Insert cool slogan here
usafracer's Avatar
With a goose neck you shouldn't have any problems. Its 5th wheels that you have to be careful with.
2010 GMC Sierra CC SB 4X4 6" lift and 315's
2008 GMC Sierra Crew Cab 4X4 (wifes) stock now... Zone lift going on and 305's
usafracer is online now   Reply With Quote
Old 01-01-2013, 06:19 PM   eBay Motors  #4 (permalink)
Ezkieler850's Avatar
Is the truck lifted?
Ezkieler850 is offline   Reply With Quote
Old 01-01-2013, 06:55 PM   eBay Motors  #5 (permalink)
It's actually my buddies truck. And no it's not lifted.
Old 01-01-2013, 07:06 PM   eBay Motors  #6 (permalink)
You should be good then as long as you're towing the trailer level.
Old 01-01-2013, 07:25 PM   eBay Motors  #7 (permalink)
They make extensions for the trailer neck to move the hookup point back in the bed. I have a couple friends using one for there shortbed trucks w enclosed gooseneck racecar trailers.
TubbedTruck67 is offline   Reply With Quote
Old 01-01-2013, 07:58 PM   eBay Motors  #8 (permalink)
DenaliDuallyHD's Avatar
Hook it up and take the truck/trailer to a parking lot and test how far you can turn with the trailer. that is what I did with my 5th wheel with a tool box in the truck.
Also se below if you need to move the trailer back some:
4" Extender - Turnoverball? Accessory | B & W Trailer Hitches
JohnnyO
2012 Denali Dually HD 4x4
Banks Exhaust, Ram-Air & Custom Super-Scoop
Line-X, BedStep, BedStep2, Bed Rug
B&W Turnover Ball Hitch with Companion 5th Wheel Hitch
American Work Cover-rolling cover/toolbox w/ B-light tonneau lighting system
1993 GMC 1500 SLE Extended Cab Short Box, 4x4, 5.7 gas, traded it for:
1996 GMC 3500 SLE Crew Cab Dually, 4x4, 7.4L gas, sold it and got a:
2003 GMC 2500HD SLT Crew Cab Short Box, 4x4, 8.1L gas, traded it in for the 2012.
DenaliDuallyHD is offline   Reply With Quote
Old 01-01-2013, 09:26 PM   eBay Motors  #9 (permalink)
premis's Avatar
WRONG!
I have a CCSB truck and I towed a enclosed GN. I used this on the trailer (9 inch version)
Extended Gooseneck Trailer Coupler
I still have two cab dents after about 80,000 mies of towing. It will give you about 80 degrees of turning, without it you are looking at 45 degrees.
As for the tool box, if it sits high enough above the bed rails for the trailer to hit it, it will need to go.
Towing it straight is no problem, maneuvering is a whole different issue.
2005 Black Duramax Crew Cab Short Box
Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's
premis is offline   Reply With Quote
Old 01-01-2013, 10:33 PM   eBay Motors  #10 (permalink)
Originally Posted by premis View Post
WRONG!
There's always going to be a limit to how far you can turn, which apparently, you didn't realize until after you dented your cab. The trailer you towed must be identical to the unknown trailer he hasn't bought yet.
I was going to give a more in depth answer, but I ran out of time. There are alot of different scenarios that you can hit the back of the cab or the bed of the truck. Turning sharp, going up or down a short steep inclines and turning while going up a short incline makes it even worse. You also need to make sure you have enough gap between the bottom of the trailer and the top of the bedsides.
Some people never need to turn past 45-55 degrees. Once you start getting closer to 70-90 degrees it puts alot of stress on the trailer suspension and I've even seen people pop tires off the beads and bend hanger brackets. Sometimes you need to turn that sharp and I've done it myself (while making sure I didn't dent the cab).
Like others have said there are offsets, but which one and what type you'll need really depends on the trailer and the type of manuvering you'll be doing. For instance if you have a v-nose, how far foward on the trailer your goosneck is, if you have any supports or struts for the overhang, etc. Sometimes using an offset on the trailer side can cause clearance issues when turning or going up and incline inside the bed. In that case, the offset ball that plugs in the hitch would be the best.
I'm sure there is alot I've missed, but there is no blanket statement that can be made with out seeing the trailer. Like others have suggested you need to hook it up and do some test turns in a empty parking lot to know you're limits.
