Its not so much pullin as it is the stopping I think you will be fine
__________________ 2006 Silver Birch LBZ, LT2, Extended Cab Short Bed
4" MBRP Turbo back with cat delete and 5" tip, EGR blocker plate and finger stick, Autometer Cobalt pyro and boost gauges, EFIlive, Ranchhand grill guard, 285 75 R16's, All head lights on mod.
sorry if i came off rude but something i didn't mention is my trailer runs electric over hydraulic and with any weight you need to take extra care in checking all systems of your truck and trailer, stay off peoples tailgates and always be checking your mirrors for ways out out of trouble. like monster truck said if you get a truck to barrow with that settup try it and see if you feel safe with it
I pull a 50' wedge trailer with my 3500 drw w/ 3 cars on it all the time. I can pull 19,000lbs of trailer and still be legal as far as I know. What most people don't consider is that when DOT weighs you your 17k trailer may only have 12k-14k on the trailer axles. As long as you have your truck licensed with the right combination weight you will be OK. The Duramax and Allison has no problem pulling this weight on hills and I have never had any problems with the tranny or engine getting even slightly hot. Just make sure you keep your trailer and truck brakes and brake controller in good working condition and drive with a little common sense and you will be fine.
I found this trailer loading/weight calculator that lets you get as detailed as you want when examining the capabilities of the tow vehicle. It is an excell spreadsheet and self explanatory to use. I am using it in my search for a 5th wheel toy hauler.
I tried to upload it without success but it can be found here RV and Tow Vehicle Weights there is a link at the bottom of the page titled Calculate Tow Vehicle / Trailer Weights Using This Excel Spreadsheet Demonstrator.
Reason: Could not upload .zip file
im not real sure what your legal GCVWR in your states might be....but in kentucky with a farming license plate "farm tags" your allowed 32,001 lbs without cdl...heavy...but legal...i have been right at 32,000 lbs GCVWR...with my dually.....it pulled great..and stoped just fine.....
__________________ 2006 Chevy Duramax LBZ 3500HD CC Dually LT3 4X4
Allison 6-speed automatic. Leather Heated Seats, Bose XM Stereo w/6CD changer
4" MBRP turbo back exhaust, 5" pollished stainless steel tip, & Turbo Resonator plugged!
Edge Juice with Attitude.
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
B&W turnover ball
Michelin LTX A/S 265/75/R16, 2" spacers
Lost Kitty! EGR Block Plate and Fingerstick-not installed yet..
If you think about things from an engineering perspective, Everything on any truck is way overengineered. Think of a bridge, they say its safe to haul 20 tons on, but that doesn't mean if someone runs 21 tons on it, that it'll fall down. I'm sure the duramax is built to handle 25k-30k or more easy, but they rate it at 15-16k to cover their a$$es. It's common practice in any design. In engineering its called the factor of three or something like that. Build it so it can handle 3x its rated capability.
I'd say give it hell with the dmax dually. Its a GM, it'll handle it as long as the trailer brakes are up for a workout.
ive seen people towing 45 foot toyhaulers to glamis with chevy 2500hds and f250s, they have to weight at least 17klbs... with toyhaulers in them, and a trailer with 3 slides...
Obviously you have a Class A license. Now, the ramifications of towing over the GCWR of the truck. There is a question. I have a customer that runs an equipment business. He hauls a Case 580 Super M (IIRC) and he has his truck registered for 35K GCWR. It is over the manufacturer rating, but registered with the State DOT, so its legal. I would talk to your local Highway patrol or State Troopers about this to get an accurate answer on the legal side of this. The truck can handle it all day long, but you need to look at the legal side of things.
__________________ We are very busy in the shop, please call for fastest service!
Kodiak C5500
The tough Chevy Kodiak C5500 has the power and versatility to work hard for your bottom line.
Now available as a 4x4 on Regular Cab and Crew Cab — which carries up to six adults comfortably
GVWRs: up to 26,000 lbs(1)
Engine choices include Vortec 8100 MD V8 gas engine or a DURAMAX™6600 turbo diesel engine
Standard automatic new vocational Allison transmission
Frame strength: up to 80,000 psi
One of the best turning diameters within classes 4 and 5 — for turns even tighter than most full-size pickups and some midsize cars(2)
Big windshield and sloped hood — for great visibility
Built to help reduce costs with easy maintenance and service — including an impressive warranty(3)
__________________ 08 Chevy Silverado 2500HD Crew 4x4
6" Fabtech Lift, Pro Comp 35" Tires Extreme A/T & wheels
ATS Extreme Trans w/CoPilot
Quadzilla Stealth 2
4" Turbo Back Silverline System
BD-Performance Exhaust Manifold
Kennedy Diesel Air box Mod & Resonator plug
6k/8k HID Headlight Upgrade
Possible, but not recommended. I use to haul heavy just 'cause I could, but in retrospect it wasn't worth the damage I caused. I've torn out motor mounts, cracked bell housings, destroyed drive lines and taken out the rear end on my '72 1/2 ton 4X4. My last trip over Roger's Pass convinced me otherwise when the torque converter stalled and the engine sat there pinging. Thinking I was smart, I slid her into low range and took it over the top only to roast the brakes (even the trailer brakes) on the down hill side. My take home was 16,500 lbs of fire wood and a worn out pick-up. 25 years later I know better and fully appreciate dual rear wheels where there is a goose neck trailer in the picture.
Just MHO here...
