hey guys, i'm looking for a goose-neck trailer to be town behind my truck. whats the best combination as far as length, weight, and wheel base. just so i dont overload the truck and get tickets. thanks
__________________ '06 Silverado 2500HD, lbz, CCSB, greystone color, 5" Magnaflow SS turbo back, Evo race lvl 5, blocked EGR, Cooper S/T on 09 stock wheel, S/C stage V w/1056, BD manifold, PPE lift pump and race valve in the box.
mostly smaller equipment, tractors, skid-steers, truck/cars if need be, stuff like that. i guess my question would lean more on what weight i could have on the tongue on the truck and how heavy of a trail to go with. my father has a 20k lbs trailer that i used with a JD tractor and a t250 bobcat on it but i think i was right on the border or tongue weight or i was over. that trailer is a 32 footer, i dont think i need a trailer that long but I'm not so sure i wouldn't use it.
what’s the best combination as far as length, weight, and wheel base. Just so I don’t overload the truck and get tickets… mostly smaller equipment, tractors, skid-steers, truck/cars if need be, stuff like that…
As you well know from hooking onto that 20k GN (you were overloaded), because of weight limitations with a 2500HD, you’re going to be limited in GN choices versus having a 3500DRW to pull with. Staying within the limits of your HD, with the small tonnage you’re proposing to haul, going with a tag trailer instead may be a better option and much cheaper too.
Generally, an empty GN will weigh more per foot of trailer than a comparable tag trailer will, thus reducing your trailer’s hauling capacity in relation to axle limits. Your best bet would be a 20’ open car-hauler style tag trailer with tandem 8-lug 7k brake axles. This will give you 10k lbs of hauling capacity and 1250 lbs of tongue weight, which is within the limits of a stock 2500HD D-Max, and plenty of trailer to haul the items mentioned.
i have pulled 20,000 many times with the 3/4 ton with air bags and she does just fine. as for GN trailers. most are 16-20k in the size youll probably want. dual wheel trailers over singles are also nice. the trialer dad and i have is a 20k, tri axle with dual. its 18 on the flat with a 6 foot trails and then the neck. here is a pic with the burnt up tractor from your hay barn fire this last summer
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
I have a 25ft 20k gooseneck. I like it for hauling hay and big awkward stuff. I mainly need it for the size as I dont haul really heavy stuff. I would love to have a 20-24 ft 14k goose lowboy with a tilt deck. They are awesome for loading vehicles, skid steers and small equip.
__________________ 01 GMC 2500 HD DMAX 4WD 66k all stock
03 GMC Yukon 5.3 Bilsteins 130k
i have a 25 foot gooseneck, w/ the king pin for fifth wheel hookup and i love it...its an appilacian and its 14k....and you can buy them pretty reasnable..i just haul my off road cars with it and some tractors now and then.
__________________ -2007 GMC 2500 EXT.Cab short box
I have a Quality Brand 7k 19ft car hauler and Im happy with it! There out of ohio. Not tryin to hurt anyones feelings but I saw some stuff at the appalacian trailer factory. Id never buy one of them.
This is from last week. Had the dinky tires on
i have been searching around looking for some info on a gooseneck trailer. i am looking at picking one up and am thinking about a 25 foot gooseneck. My question is i currently have a 16 foot bump hook flat bed and when i load a car it hits due to the load angle of the ramps to the deck. is the angle of the beavertail on a gooseneck going to cause this problem as well. I need to know what to expect.
__________________ 2006 2500HD Crew LLY
EDGE EVO RACE
MBRP 4" exhaust from the turbo back (the kitty used its ninth life)
Transgo JR
Amsoil from the fan to the rear tires
THANK YOU HUSKER DIESEL AND BIGDADDYDIESEL FOR YOUR HELP.
