Old 11-03-2009, 02:03 PM   eBay Motors   #11 (permalink)
diesel guy
diesel guy's Avatar
Ok thanks and that fuse is a 40 amp right?
2008 2500hd duramax crewcab Whelen 90 watt strobe lights Cobra 19dx iv cb radio with a 4'Firestik antenna
toys 2007 thor tahoe 22fb toyhauler 2005 honda 450 quad 06 polaris 200 auto(wife) and 06 polaris predator 50 (son) Seadoo gti se 155
diesel guy is offline   Reply With Quote
Old 11-03-2009, 09:01 PM   eBay Motors   #12 (permalink)
rmcable
rmcable's Avatar
Yeah GM does not include proper direction or even the Nut for the stud. went thru that on my 07 5.3. I actually found instructions complete with pictures on the net.
2009 Chevy Duramax, LMM, 6 Speed Allison,
Black, 4 dr, 4wd
Mods:
Edge Evolution Tuner,
Level 3
T-Bars Cranked,
Modded Airbox...... So far.
YEAH I already know, DELETE the DPF.
Gun's don't kill people; Daddies with little girl's KILL people!
rmcable is offline   Reply With Quote
Old 11-04-2009, 07:24 AM   eBay Motors   #13 (permalink)
diesel guy
diesel guy's Avatar
Yeah I already installed a Prodigy a few months back when I first bought the truck but I want to add more stuff to it.
Old 11-04-2009, 05:37 PM   eBay Motors   #14 (permalink)
Len Todd
On my '09, there are two Red/Black Aux Power wires located under/near the under-hood fuse box. One is taped to the harness between the fender and fuse box. The other is taped to a different harness between the engine and fuse box. This one was actually pushed under the fuse box and hard to find. Also, there is a third Red/Black wire which is for the trailer brakes, which was/should be already hooked up to the stud on the fuse box closest to the engine.
To get Aux Power to the rear bumper you have to hook up the Red/Black wire that is located between the Engine and the Fuse box to the stud on the front of the fuse box that is furthest from the engine If you have a 5er or a truck camper, you need to hook up the Red/Black wire that is located between the fender and the fuse box and add a harness under the front of the cargo box. You do not want either Aux Power wires on the same stud as the Trailer Brakes.
Both of my studs, in the under-hood fuse box, already had 40 Amp fuses in their circiuts, which are located just inside the fuse box by the studs, under the cover. Both studs are on the outside front of the fusebox, but under the cover. Apparently, GM stopped inserting dummy fuses.
'09 2500 Z-71 HD with Allison
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
Len Todd is offline   Reply With Quote
