I'm installing a prodigy brake controller in a 2007 Siverado 3500. I found the brake controller wiring loom under the dash. The power wire Red w/ black has no power. The fuse box under the hood does not have a fuse locations for the brake controller. Does anyone know where this is located? Also what is the orange wire for? is this for the ITBC?
Wire was next to the fuse box wrap in tape on the underside of the loom. That wire goes to the the stud 1 post to the front of the fuse box - that post is connected to 40a fuse. I hope this helps someone else out.
__________________ Mine- 05 RC/LB D/ZF-6-Twin turbos, twin pumps, Tripple clutch Hers-04.5 CC/SB D/A Big turbo, Big pump, Big trans runNADM.com
EFI Live By whoever my tuner "barrowed" his tunes from!
i ran into that when i installed my controller on the LBZ..
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Jim
Jim,
Is this wire located inside the vehicle, or under hood?
I'm currently trying to figure out why my Accessory connection is not working on my 09.
THANKS!
Corey
__________________ 2009 GMC Dually D-Max Crew Cab, Long Bed.
(Former 02 6cyl ISB Owner)
Stock where it counts, Front hitch/Winch plate, Warn 16.5 Ti winch, Line-X bed & Rocker Pannels, Wheel Wells, Bumper guard (rear), OEM Cargo management system, 70 Gal Combo Bed tank, OEM Step Bars, B&W 30K-Turnover GN, Ride-Rite Air bags, NAV "Lockpick"...
12 Years Air Force, 1.5+ Army (UH-60 MedEvac Baby!)
"I do not fear death, I grasp it with both hands and twist the throttle". www.coreyperez.com www.408shooter.com
Well I just ran outside and looked under the hood. I had already spent about 3 hours scouring through the owners manuals and found what I thought I was looking for. Granted, I was lead to believe that the wire was a "blunt end" in a loom under the dash, behind the instrument panel. But I found it next to the master cyl under the hood... Guess I know what I'm doing tomorrow... I really would like to B!tc# slap the people at GM... Couldn't just hook it up and leave the fuse out huh????
The 'blunt' bundle is inside by the parking brake, for an aftermarket controller install. Under the hood, check for the fuse first. There may be two wire bundles, one for the controller, and the other for your 12v feed.
Hey Horns!!You know the stems that you connect power and ground too in the fuse box,what else can you connect there for power?That's only 12v right?Can you maybe hard wire a portable gps to that and other small things???
__________________ 2008 2500hd duramax crewcab Whelen 90 watt strobe lights Cobra 19dx iv cb radio with a 4'Firestik antenna
toys 2007 thor tahoe 22fb toyhauler 2005 honda 450 quad 06 polaris 200 auto(wife) and 06 polaris predator 50 (son) Seadoo gti se 155
I wouldn't see why not... Just ensure what ever you are connecting to it doesn't over rate the fuse that is connected to it.
