Old 10-05-2009, 09:03 AM   eBay Motors  #1 (permalink)
maybe a new trailer
Hi
I have a 05 Chev 2500 HD extended cab with I presume the LLY and a 5 speed tranny. I now have an Eagle Superlite 28.5 that I am not particularly happy with. I pull the trailer and hardly even know it's there. The pin weight is approx 1500 lbs and the dry weight is a tad over 8000 lbs. I have been looking at a BigHorn 3050 that has a pin weight of 1950 and a dry weight of 11000 lbs. In your opinion do you think I need bags to help with squatting and handling? Do you think I can pull this trailer and more importantly stop this trailer with the truck I have? It is stock and I would really like to leave it that way if I can. Need opinions.
Rick
Ricoh is offline   Reply With Quote
Old 10-05-2009, 04:39 PM   eBay Motors  #2 (permalink)
bpe1's Avatar
If dry weight is 11,000, add any dealer add on equipment weight to that. Also figure on about 1000 pds per person when loaded. This unit could easily go 15,000 lbs. You would need air bags with a 2500. Lots of people do pull this much weight with a 2500 but I would not. I'd get a 3500. Much more stable also. Better brakes (trailer brakes can fail).
05 GMC Sierra, 3500, lly, 4x4, CCLB, dually, LBZ mouthpiece, Hook'em Horns cai mod. EGR bocked, 235X85. 2006 Mobile Suites 32TK3 5th wheel rv, 15,600 lbs.
bpe1 is offline   Reply With Quote
Old 10-06-2009, 06:02 PM   eBay Motors  #3 (permalink)
midieselguy's Avatar
You'll be fine, I pull 10,000 lbs and it doesn't feel like there's anything back there. I wouldn't hesitate to pull a 15,000 lbs load. I think you'd be hard pressed to load 4,000 lbs into that trailer.
2004.5 LLY, X-Cab, short-bed, Allison Trans, 4" MBRP Turbo-back, no cat, KB's IOH kit, EGR block plate, no finger stick, deep trans pan, MB Razor 16x8 with BFG AT 285's
midieselguy is offline   Reply With Quote
Old 10-07-2009, 03:41 AM   eBay Motors  #4 (permalink)
bpe1's Avatar
Most people that actually weigh their rv's find they are near or above the max weight rating loaded. Check out rv forums. This is the norm.
Old 10-07-2009, 03:57 AM   eBay Motors  #5 (permalink)
mijdirtyjeep's Avatar
I would just put bags on the back and haul it. The difference between the 2500hd and the 3500srw is not very much anyways "GVWR difference is 9200 vs 9900 lbs", i am sure those bags more than make up the 700lb GVWR difference
Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2
http://www.getsomeperformance.com/
mijdirtyjeep is offline   Reply With Quote
