Tow haul mode/overdrive not working??? - Chevy and GMC Duramax Diesel Forum
Old 10-10-2009, 08:04 PM   eBay Motors  #1 (permalink)
Unhappy Tow haul mode/overdrive not working???
Hi, Iam new to the forum. Just bought a 2003 w/58,000 miles.
This is my 1st diesel and love it. I just found out after reading manual that I have overdrive and tow haul mode. I have tried several times pushing the button on the end of the column shifter, but I dont see anything on the dash indicating engagement. I have a hard time finding Park. The original owner told me it needs a Neutral Safety Switch. Could this be related to my OD/Tow mode problem??? Any help would be fantastic Please. Thanks guys!
Seattle, Washington
76greenmachine is offline   Reply With Quote
Old 10-11-2009, 02:16 PM   eBay Motors  #2 (permalink)
im not sure what to tell you but when you push the button when your at speed it should take off overdrive and shift differently. It should give you a light but not sure on that truck. As for the safety switch, im not sure but do a search and you should find something.
2009 chevy 2500HD Dmax
8500 miles and bone stock right now
midwest 09 dmax finally is offline   Reply With Quote
Old 10-11-2009, 02:48 PM   eBay Motors  #3 (permalink)
LHN...We ARE the Joneses
Tap the shifter button to engage the T/H, showing a dash icon as enabled. Push and 'HOLD' the same button, 'O' is then disabled, showing icon on the dash.
Old 01-29-2010, 09:57 AM   eBay Motors  #4 (permalink)
I have an 06 and have the same problem. The dealer troubleshot it and said the wiring harness between the switch and the steering column came open. A new switch (and harness) will be about $100. including the install. Its on my to do list. I wonder if this is a common problem with those tow/haul controls?
Paul
06 LBZ 2500HD CC, 4x4, SB, Edge Evo, MBRP Cool Duals
08 Wilderness Extreme Edition 2652BS 5er
va3pc is offline   Reply With Quote
Old 01-29-2010, 10:09 AM   eBay Motors  #5 (permalink)
Kroggs's Avatar
More then likely the wire has been chewed through. Depending on wher it is you can splice them back toghether a lot cheaper then a new shifter. I did it on mine and works fine easy to do also.
2005 LLY Gmc 3500 CC/LB not bone stock I have a brake controller!!!
Thanks to Tyler @ www.meyerperformance.com
Thanks to Chad @ http://www.alligatorperformance.com/
http://www.facebook.com/group.php?gi...?id=1210592953
Originally Posted by MNDiesel View Post
I hate to derail, but how do you get a quote in your sig?
Like this^^^^^^^
Kroggs is offline   Reply With Quote
Old 01-29-2010, 10:19 AM   eBay Motors  #6 (permalink)
gya0ma7ha's Avatar
My truck has a 175K on it and haven't had that problem yet. Must just be unlucky. Sorry about that.
TEXAS A&M ENGINEERING
SOLD: 2001 2500HD LT CCSB 4X4 LB7
AKA: "WHITEY"
Tuned by SCRTuning: 431 HP 823 TQ
New Truck:
05' CCSB 2500HD 4X4 LLY Code Name:Lilly
2 inch drop Shackles and Front set to match
LBZ Mouthpiece, 5" TBE, EFILive by SCRTuning
gya0ma7ha is offline   Reply With Quote
Old 01-29-2010, 05:40 PM   eBay Motors  #7 (permalink)
Brad92's Avatar
The tow/haul button wire is probably broken. It is common for that to happen, especially if the wheel is tilted up and down alot. Check the orange wire to make sure it isn't broken, or at the connections.
2004 Chevy Silverado C2500HD CCSB LB7. (THE TANK) Pretty Much Stock, Fully Loaded, Fleet Emissions, Crappy EGR
1997 Chevy Suburban C1500 (The Bus)Stock, The 350 is still going strong at 170,000+
2002 GMC Sierra C1500 RCSB 4.3 V6 (The Green Machine)Misc. Headlight Mods, 6000K HID's, K&N filter, Airbox mod, Throttle Body mod, Resonatorless, Radar Detector, Garmin GPS and others. Sound System by Alpine, Pioneer, and MTX.
Brad92 is offline   Reply With Quote
Old 06-27-2010, 08:05 PM   eBay Motors  #8 (permalink)
ALT-B's Avatar
Anyone have any instructions on getting to where the wire might be broken? - mine just went out too.
2002 2500HD Duramax 4x4 | Hypertech on Level 3 | AIRAID Filter
2007 C5500 LMM (2008 FourWinds Chateau RV - 34')
ALT-B is offline   Reply With Quote
Old 06-27-2010, 08:09 PM   eBay Motors  #9 (permalink)
Kroggs's Avatar
Take the cover off that is over the hazard light switch and look for a orange wire at the bottom conected to the shifter.
Like this^^^^^^^
Old 06-27-2010, 08:15 PM   eBay Motors  #10 (permalink)
ALT-B's Avatar
Thanks Kroggs - any "typical" break location?
Also I thought I read somewhere to be careful about accidentally deploying the air bag - anything to be concerned about?
