Old 10-15-2009, 10:18 PM   eBay Motors   #11 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
anything over 3k for me.
Old 10-30-2009, 04:26 PM   eBay Motors   #12 (permalink)
tcharon
Mine has enough torque to pull any passes empty no sweat. Down also OK. Don't use w/ 2K lb trailer but do w/ 7K. Not w/ just 4K lb camper on, up or flat but do down. I switch it off even towing if I need to cruse about 50 flat, for better mileage but flip it on if it gets hilly. I just go easy on the skinny pedal then.
05 Silverado 2500HD 4x4 2" lift Red Crew Long, Bully Dog, 4" Turbo-back S/S Exhaust w/ Aero-Turbine & 6" tip, EBC sport rotors w/ Yellowstuff pads, Firestone air spring bags, AEM filter, Lowrance Baja 480c GPS, HIDs, Warn 12K winch, Superhitch
tcharon is offline   Reply With Quote
Old 10-30-2009, 04:46 PM   eBay Motors   #13 (permalink)
Johnp33
I use it in the steeper parts and take it off on the flat higher speed sections. Above 9,000lbs I use it most of the time it is a bit harsher shift, but less RPM, in the lower gears, stays in 5th longer. Seems to go almost directly into lock-up.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline   Reply With Quote
Old 10-30-2009, 05:05 PM   eBay Motors   #14 (permalink)
SteepyBS
SteepyBS's Avatar
I run mine with the truck unloaded, my daily drive includes a 7% grade for a little over a mile both ways, i just click it on and the truck coasts down no brakes needed
also if i want to have a little fun i leave it on over flat ground for that better acceleration. it wont hurt the tranny to run w/ t/h on but at cruising speeds and daily driving I wouldnt use it just cause of the lower fuel economy
Im Brandon, 18 from Seattle
03 Silverado 2500HD LT crew cab LONG bed
6" tuff country lift 315x75x16 on Raceline Renegades
Edge juice with attitude
aFe intake and Dual 4" exhaust
added tow mirrors, nerf bars, reverse lights
tweaked and tuned CB for police warnings
->77 Camaro Type LT 350sbc/TH350
and i paid for both my own rides
SteepyBS is online now   Reply With Quote
Old 10-30-2009, 06:37 PM   eBay Motors   #15 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
i use mine to kill riceers cause i dont haul much i live howit shifts tho it pulls way more boost aswell
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
Old 10-31-2009, 12:34 PM   eBay Motors   #16 (permalink)
midwest 09 dmax finally
i use it to start and stop with my 7k enclosed work trailer but not all the time,
i use it all the time with the skidloader which is around 12k
It really helps on the accelerating and with braking
It however doesnt hurt anything except for your wallet at the pump.
2009 chevy 2500HD Dmax
8500 miles and bone stock right now
midwest 09 dmax finally is offline   Reply With Quote
