Old 11-06-2009, 08:39 PM   eBay Motors   #1 (permalink)
vtecjun
Question about snow chains 35" tires
Sorry to bring this back from the dead, but who else has had any experience with putting chains on 35" tires? I have a set of 20" wheels with 35" Toyo tires and I need to make a trip down I-5 from Seattle to Ontario, CA. On my way I will need to pass through the Siskiyou Mountain Pass which sometimes requires chains. I will also be pulling a 44' gooseneck trailer.
Just looking for some good advice. Thanks
2003 2500HD Crew Cab White
vtecjun is offline   Reply With Quote
Old 11-06-2009, 08:41 PM   eBay Motors   #2 (permalink)
maxxflip
maxxflip's Avatar
Are they mud terrains?
08 LMM
Tuned by ʍʍlʍʍ
maxxflip is offline   Reply With Quote
Old 11-06-2009, 09:02 PM   eBay Motors   #3 (permalink)
vtecjun
They are the A/T Open Country tires.
Old 11-06-2009, 09:10 PM   eBay Motors   #4 (permalink)
maxxflip
maxxflip's Avatar
OK i was going to call you crazy attempting that on mudders
Just make sure they are the right size and tight
08 LMM
Tuned by ʍʍlʍʍ
Old 11-18-2009, 03:15 PM   eBay Motors   #5 (permalink)
prick62
prick62's Avatar
I took a set of semi chains and cut them down to fit my 35"x12.5"x16.5" BFG's. You have to cut about 6 to 8 inches off but they worked great! I also did this for a set of 33's too. I prefer the cam lock style over the p-wag chains! Just make sure you have them tight, I drive about 100' and check them again then do it again after you been on the road a little bit. And always have a chain tension cables on or bungee cords if thats all you have over the face of the rim! The tension will pull the chains off the tire and towards the outside of the truck if they do break, and not to the inside where you will tear up your brake lines, steering and just have a complete mess!
Ps. I run a snow plow in the winter for our City Public Works!
VEHICLE: 2003 GMC Crew Cab Dually 3500, 63k miles, color matched grill/door handles, all emblems removed, billet grill, custom wheels (UGLY)
PERFORMANCE PARTS: K+N Intake, Magnaflow 4" Exhaust w/ 5" tip, Edge chip removed (JUNK-blew out crank sensor twice)
EXTERIOR ACCESSORIES: Lowered 6" Front-8" Rear, C-Notched, Axle Flipped, Transmission Cross Member Raised, Firestone compressor and air bags, bullet proof steering tie rods with Heim joint ends, 3.73 Posi
prick62 is offline   Reply With Quote
