Old 01-19-2008, 07:42 PM   eBay Motors   #1 (permalink)
JuniorDiesel
Points: 550, Level: 8
Points: 550, Level: 8 Points: 550, Level: 8 Points: 550, Level: 8
Activity: 0%
Tow mode
When towing a big 5th wheel down the highway, do you leave the truck in tow mode the whole time or just when starting, stopping and going up hills? I also have the EDGE w/juice module in my truck and it also has a tow mode. I am not sure if I am supposed to have both on at the same time, one or the other?
2007.5 Silverado 2500HD LMM
S&B Air Intake System
JuniorDiesel is offline   Reply With Quote
Old 01-19-2008, 10:33 PM   eBay Motors   #2 (permalink)
Tow Master
Super Man Moderator
Points: 10,685, Level: 44
Points: 10,685, Level: 44 Points: 10,685, Level: 44 Points: 10,685, Level: 44
Activity: 88%
Activity: 88% Activity: 88% Activity: 88%
Tow Master's Avatar
All the tow button does is make your shifts longer so it gets higher RPM's in each gear. Then there will be more power during low rpm's at the start of the next gear. I dont think it blocks out over drive. Id say if your doing 60-70mph on flat ground and the RPM's arent any higher than they are if you unloaded your fine. If there almost in the red take it out of tow/haul mode.
Its ok to use both the edge and stock tow modes at the same time.
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Old 01-20-2008, 08:32 AM   eBay Motors   #3 (permalink)
05duramonster
Points: 591, Level: 8
Points: 591, Level: 8 Points: 591, Level: 8 Points: 591, Level: 8
Activity: 0%
I noticed yesterday that the allison on tow mode just flares each shift to keep the boost up. does this not damage the trans, its like it slips into each gear? I just bought my truck and it has bully power pup on performance right now. my trailer was unloaded 18 ft. car hauler. it just doesnt feel right? any help with this
05duramonster is offline   Reply With Quote
Old 01-20-2008, 08:56 AM   eBay Motors   #4 (permalink)
08LMM
Points: 399, Level: 6
Points: 399, Level: 6 Points: 399, Level: 6 Points: 399, Level: 6
Activity: 0%
How do you post?
2008 2500HD 6.6LMM Crew 4x4 LT2
Billet Grill with SS Bowtie
295/70x17 Nitto's All Terrian
08LMM is offline   Reply With Quote
Old 01-20-2008, 10:05 AM   eBay Motors   #5 (permalink)
truckmasterflex
Points: 1,427, Level: 15
Points: 1,427, Level: 15 Points: 1,427, Level: 15 Points: 1,427, Level: 15
Activity: 1%
From my understanding the tow haul mode just locks your torque converter. It doesnt hurt anything to drive it around like that, my buddy has PPe hot 2 in his lly and he says it runs better in tow haul mode.
truckmasterflex is offline   Reply With Quote
Old 01-20-2008, 07:51 PM   eBay Motors   #6 (permalink)
loubazooka
Points: 494, Level: 7
Points: 494, Level: 7 Points: 494, Level: 7 Points: 494, Level: 7
Activity: 0%
loubazooka's Avatar
tow mode
tow mode on newer models also helps with downshifts on your allison tranny so you don't have to use the brakes as much.
loubazooka is offline   Reply With Quote
Old 01-21-2008, 01:40 PM   eBay Motors   #7 (permalink)
AJJ892
Points: 305, Level: 6
Points: 305, Level: 6 Points: 305, Level: 6 Points: 305, Level: 6
Activity: 0%
tow mode
just leave it tow mode while hooked up. It does not lock out overdrive. You can use the manual overdrive lock out when climbing steep inclines so you're not shifiting in and out of overdrive all the time. AS far as transbreaking on the down hill side, I've pulled 3500 rpm for short periods. When I got home I asked my buddy at a GM deakership about the high rpms and was told it was no problem. he said the red line on the tach is basically meaningless, the engine can more than handle it.
AJJ892 is offline   Reply With Quote
Old 02-01-2008, 06:28 PM   eBay Motors   #8 (permalink)
Meridian
Points: 414, Level: 7
Points: 414, Level: 7 Points: 414, Level: 7 Points: 414, Level: 7
Activity: 0%
I to have the power pup on my 05, At first I had it on the performance mode and the shifting felt funny loaded or unloaded, put it in the tow/econ and the truck shifts great and seams to run better loaded or unloaded. Just my 02
06 Chevy 4x4 ExtCab SB LBZ LT1
Bully Dog Power Pup
Meridian is offline   Reply With Quote
Old 02-01-2008, 09:28 PM   eBay Motors   #9 (permalink)
05duramonster
Activity: 0%
Yeah i talked to Idahorob about it and he said it sounds like it is all the bully dog. i am in the process of getting edge!
05 LLY crew cab. Charcoal grey met. 4x4
PPE Hot xcell stacked with edge, air filter, 4" turbo back straight pipe, egr!, afe drop in filter,PPE shim kit 3, drilled fuel rail fittings
20x9 Black KMC Hoss's w/ nitto terragraplers, the loudest air horn you can find@200psi, 5000K HID low beams and fog lights
89lx mustang way too fast.
461cid lsx 1 kit=4.80's
Old 02-02-2008, 01:06 AM   eBay Motors   #10 (permalink)
n0useforaname
Knows your Mom
Points: 4,892, Level: 29
Points: 4,892, Level: 29 Points: 4,892, Level: 29 Points: 4,892, Level: 29
Activity: 100%
n0useforaname's Avatar
I personally don't like tow haul mode....makes me feel like I am wasting gas and it almost seems un-necessary. If I were towing or hauling a crap load of weight....I would probably use it...but if I didn't have to...I wouldn't.
RIDE: 07 Silverado Classic Crew Cab
ENGINE: Duramax/6 Speed Allision LBZ 6.6
LIFT: Ready Lift Leveling Kit
STARTER: VIPER 2 Way w/ Turbo Timer
ADD ONS: H1 Halo Projector headlights, Back up Camera, Dee Zee running boards, Chrome Billet Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS System
TIRES/WHEELS: 265/75-16 Grabber AT2 Tires on 16x8 ATX series Teflon Coated Wheels
PIPE: Banks Monster Dual Exhaust
CAI: Banks Ram Air
PROGRAMMER: Banks 6 Gun PDA w/Speed Loader
n0useforaname is online now   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104
