Ok guys, I have an 06 3500 CC Dually. I loaded it a few minutes ago with my gooseneck (7140 lbs) and a sammy (3k lbs?) and my jeep (4980 lbs). Question is, how would you load the crawlers? Heavier in the rear? that is how I have it now, but I am not getting a warm fuzzy. Here are some pics as best as I can get them.
Truck does not seem to be squatting that much at all. Also the goose just seems like it may not be level. I know I am just being paranoid probably because this will be the heaviest and farthest towing with this truck so far. The book says max trailer weight is 12k, but I am thinking that is for a bumper pull...I have just over 15k total
see my sig...you should have no probs....load looks good
__________________ Byron
2005 liLLY 4x4..... ZF 6 Speed , no muffler, lost kitty, Autometer C2 Pyro and Boost Gauges, EGR Blocker Plate, PCV Re-route, Resonator delete, By-Pass Dual Filtration, Amsoiled front to rear, Fumoto Valve, Texas Ranger CB. proud to be an American!! 106,000 MILES and counting
1999 Park Avenue 36' 5ver
2002 Hart 6-Horse GN
2 Welsh Corgis and 1 Aussie Shepherd
I agree with the load you have the trailer should carry the weight all you have to do is pull it (no problem). No use in making the truck carry all the weight when the trailer can (nice trailer) just as long as you have toung (goose neck) weight, you don't want it trying to lift the truck (BAD NEWS).
Looks good.
__________________ 07.5 LMM
4 inch lift, larger wheels and tires.
EFI Live (learning slowly)
Edge Insight Digital Gauge
5" MKO exhaust
with the way you have it loaded i'm sure it will be fine, the entire weight of the sammie is tongue weight and almost half of major weight of the jeep is in front of the front axle, with the truck stance looking the way it does i'd say that's a text book perfect load (don't worry about the load rating it's way under rated, it's all about what you feel comfortable with, within reason of course) i wouldn't worry about that one a bit
Good Luck
__________________ 2005 Chevy C/C SB LLY
*6 Speed ZF
*Edge Juice w/Attitude
*5" SS Turbo Back Straight
*18" Moto Metal's w/BFG A/T's
*B&W Turnover Ball, 25' Moritz GN
-coming soon n-fab SS bars, and EGR Blocker Plate
60% of the load on the rear axles of the truck and 40% on the trailer axles.
Why would you want 60% of the load on the rear axle of your truck??? I think the way the trailer is loaded in the pic's looks good and will handle fine going down the road. But, Would'nt loading the jeeps backwards on the trailer put more weight on the axles of the trailer, Since the front of the jeeps is were the weight is? Hence reducing the weight on the truck axles. It would seem you would have more then enough down pressure on your truck to avoid any lifting issues. I would think it should be more like 70% trailer- 30% truck. Please Explain how I am wrong in my thinking.
__________________ [b]05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, PPE HOT+2 ET -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, COGNITO H.D. TIE RODS & BRACES.
IMO the pics look pretty good. Id make sure the rear of the truck squats about 2-3in so if you catch rain the rear end doesnt get loose and hydroplain or loose traction some other way...
Also whos sammy? A friend of mine is really into them he has 3 or 4 now. Ones real nice almost like a show truck. Lockers all way around and transfercase gears. Some sort of jeep spring lift. That thing goes anywhere!!
