My build for a truck that can haul / tow almost anything. A lot of what I have done already is just for show.
Starting out with a 2013 Chevy LT Cab & Chassis with 9' aluminum flatbed.
Added front mud flaps running boards.
Bug shield from Stampede added and screened the front grill
Eliminated rear mud flaps add fenders under bed and mud flaps added to fenders
AT Tires were removed and Bridgestone R500 tires added. Along with TST tire monitor system with internal sensors.
Delvac. Mobile runs a promotion twice a year. $25 rebate per 5 gallon pail on two pails. So I get $100 back a year on 4 pails of Delvac. Where I get it thats under $40 for 5 gallons.
I run 15w-40 Delvac in temps above 0, switch to Rotella 5w-40 for subzero temps. On the 2010 with the bypass I average about 18,000 miles on oil changes checked with oil analyzes. I buy them at Petro Truck stops service area. I don't like to see soot over 1% so thats my limit.
The 2013 I see elevated cooper and silicone one first 3 samples. I'm limiting oil changes to 5,000 miles until oil reports improve.
One thing you have to be careful about with the NUC Bypass is the Braided hose is like a file on anything it touches. I put a hole in a brake line. Ended up sleeving it in rubber hose to prevent more mishaps.
LOL, I do read my threads daily but as I get older tend to be forgetful also, forgive me, Thanks for all the info as I am impressed with your rig and miles as well as a few others on here...Just trying to model mine after you high mileage guys...Take Care....Thanks Again
Yea I 've been looking at Transfer tanks even for what I'm doing now, doing a lot of 5th wheel RV'ing here & there....but currently still working regular job. After 32 years of playing with powerlines looking for something else with this bustedup a** body.In the near future...this is why I ask soo many questions.....Thanks
I have been dumping a bottle of Howes in at every fill up. I say about 150 gallons. Bottle reads treats 320 gallons above zero F, 160 gallons below 0 F.
I always carry extra fuel filter and bottle of 911 de-geler just in case.
Thanks for info , I live in Fla. and have been testing Fuel additives and have polls going...but for real life seat of the pants I have tried Howes Meaner Power Cleaner and it works excellent !
How do you like the rancho shocks in comparison to stock? I have 206k on my 2013 DRW, and it is starting to give me a little bit of a harsh ride up front. Been thinking of swapping shocks. Truck is a hotshot truck, and tows all the time anywhere from 20-30k out back.
The rancho 9000 is twice the diameter of the stock set. I have ran on my 2500 for almost 400k. The adjustable aspect makes them great for towing. Had to change the rear out about 100k ago. One was leaking. Haven't added to my dually yet. Might try Bilsteins for the bigger truck.
Not as good as I should. I just try to get the dirty off and wire brush what I can reach. Rust is just at the surface at this point. I don't see it as much of an issue compared to a much older vehicle where the rust is penetrating the structure.
I thinking maybe I should go without the bed. I have one of these I bought for $1100.
32,000 lb. Gross Trailer Weight
8,000 lb. Pin Weight.
Fits Pre-drilled mounting holes on most medium duty trucks.
Heavy Duty 4-way pivoting hitch head with safety lock
Shipped Direct (or to shipping facility near you) Fully Assembled
3 Year Limited Warranty
I never mounted. Planed on putting it on the flatbed but haven't. I thinking of buying a trailer like this:
I want to put campers on the top so as low as I can get the trailer is ideal.
Is that an RV size kingpin on that trailer? Most of the trucks I see with a trailer like that have a commercial 5th wheel. I can't remember the sizes, but aren't commercial 3"?
Making a maintenance record before I forget.
2,700 miles - Bridgestone R500s 235/80/17s placed on truck
5,171 - oil changed
10,461 - oil changed
18,449 - oil changed, Trans filter changed
25,279 - oil changed
30,728 - oil changed, fuel filter changed, tires rotated, front switched with 2 spares, rears moved flopped left to right inside to outside. Added finer gray fiberglass screen just in front of radiator.
Tried black plastic screen in front of grill on other truck and it just restricts too much air. Then tried this after removing and cleaning out the radiator. Much better. Its easier just to remove the screen when it fills with bugs than it is pulling the radiator gummed up.
I've been wanting to do that. Is that just window screen?
207K members
