Tow Capacity - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 12-28-2009, 03:08 PM Thread Starter
Tow Capacity
I recently purchased a 2004 3500 dually Duramax (still own my 2500 Duramax which I can't give up). I am trying to figure out what the towing capacity is with a gooseneck. Chevy corporate will only tell me 12,000 lbs. I know this is impossible as my 2500 would laugh at that towing load. I am in PA and need to find out so I can properly get a horse trailer and my 3500 registered for combined wt. The trailer will be 6-7000 lbs. Any thoughts? Any ideas where I can find this info to submit to the DOT to get this done?
Cornman is offline
post #2 of 4 (permalink) Old 12-28-2009, 03:33 PM
BUBBA3M's Avatar
Welcome to the DF!! Fill out your sig so we will know what you have. I found my info in the owners manual.
2013 LML, 6 spd Ally, CC/SB, Bone Stock
2015 Copper Canyon 33ft 5th wheel
BUBBA3M is offline
post #3 of 4 (permalink) Old 12-28-2009, 03:53 PM
Banned
max gcvwr is 23,500 for dmax dually cc/lb.
Subtract 23,500 from your unloaded truck weight. You can figure that in, from finding your max gvwr, usually 11,400 lbs, from your max payload.
Hondarider552 is offline
post #4 of 4 (permalink) Old 12-28-2009, 04:29 PM
LHN...We ARE the Joneses
Who ever you spoke to at GM Corporate has a problem with math.
Who Knew, Right?? :LMAO
The GVWR is 11,400 lbs.
The GCWR is 23,500 lbs. They are subtracting one from the other to arrive at 12,100 lbs...which is incorrect.
The ratings below are derived by subtracting the empty truck weight (7-something k lbs) from the Gross Combined Weight Rating of 23,500 lbs.
Axle Ratio.....Max GN/Fiver Trailer/Towing Capacity lbs.**
Reg Cab Long Box 4WD, dual rear wheels 3.73 16,500
Ext Cab Long Box 2WD, dual rear wheels 3.73 16,300
Ext Cab Long Box 4WD, dual rear wheels 3.73 16,100
Crew Cab Long Box 2WD, dual rear wheels 3.73 16,200
Crew Cab Long Box 4WD, dual rear wheels 3.73 15,900
These specs are all available on the GM site, if needed for proof. At least one GM department got it right...
GMC | GMC Sierra: Trucks: 1500, 1500HD, 2500HD, 3500, Denali Pickups: Sierra Specifications
Hook'em_Horns! is online now
