| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | |  | |
02-11-2008, 03:04 PM
eBay Motors
#1 (permalink)
| | DuramaxForum Fanatic
| Rear springs On my 2500hd can I put a set of 3500 springs under it without any mods?
__________________ 07 classic crew cab long bed
3.73 rear, stock tire size
5% tint on all windows, and "eyebrow" on front windshield. |
| Advertisement
02-11-2008, 03:27 PM
eBay Motors
#2 (permalink)
| | Senior Member
| IM not sure but I think you could put air bags on the back to stiffen the truck up.
__________________ 2003 Duramax lb7
stock/5spd Allison
Edge/attitude
Silverline Exhaust
4 inch turboback
AFE air filter |
02-11-2008, 03:29 PM
eBay Motors
#3 (permalink)
| Which would be the most cost effective?
02-11-2008, 03:51 PM
eBay Motors
#4 (permalink)
| | Senior Member
| I saw a firestone airbag kit for $260.00 not sure about springs. The air bags would be easy to install bolt on. I think the air bags would work good because you don't have to have them as stiff all the time they are adjustible.
stock/5spd Allison
Edge/attitude
Silverline Exhaust
4 inch turboback
AFE air filter |
02-11-2008, 04:07 PM
eBay Motors
#5 (permalink)
| You can just add leafs also, It requires purchasing longer shackles to compensate for the extra thickness. We installed an extra 2 on each side of our 04 and it rides quite well a little stiffer but not bad.
__________________ [b]05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, PPE HOT+2 ET -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, COGNITO H.D. TIE RODS & BRACES. |
02-11-2008, 08:16 PM
eBay Motors
#6 (permalink)
| | Super Man Moderator
| Ill throw another vote in for the air bags. You can fill the bags to the limit and have the truck as hard as a rock  Or let the air out to get factory ride quality.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
02-19-2008, 07:46 PM
eBay Motors
#7 (permalink)
| | Senior Member
| yes and i have set, they are a little firmer but not much, i switched to a set of wrecker prep double over load on a 3500 srw, let me know if you don't get air bags i still have the stock srw 3500 springs
__________________ 06 LBZ 3500 4x4 single rear wheel regular cab long bed WT. PPE economy, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxs. work in progress |
02-19-2008, 09:35 PM
eBay Motors
#8 (permalink)
| I have been thinking about the air bags also, just wondering which ould be the most cost efficient. John-boy, how much you want for them, and what else would I need? Longer shackles or ust bolt up?
02-19-2008, 09:54 PM
eBay Motors
#9 (permalink)
| + 1 more for bags.. the firestone's are very good units... under 300 for the bags and around another 300 for the compressor for the in cab adjust ability |
02-21-2008, 04:26 PM
eBay Motors
#10 (permalink)
| | Senior Member
| everything is the same on them "except spring wieght" but its a bolt on install. i'd like 200 plus shipping
| Advertisement
