I have an RDS 60 gallon tank/tool box combo. I bought the fuel line installation kit with it. I purchased it from Northerntool.com.( took about an hour to install- very easy) The tank feeds directly into the fuel line. The fuel gage stays full until it reaches the stock tank. I love it. The only draw back i s the size of the toolbox on top- its only 6" high. I can post pics if anyone is interested. The setup was around 800 I think.
__________________ Chevrolet Silverado 2500 06'
- 4" Rancho Suspension
-33" BFG ATS wrapped around 18" Ice Metal Wheels
-Viar onboard air compressor
-Airaid cold Air Intake, resonator plug
-Superchips- soon to upgrade
-60 gallon transfer tank/ toolbox combo
-Sound- kenwood Excelon 8120 w/ nav/ ipod hookup, reverse cam. Boston acoustics in all doors. 2 -6" base tubes w/ amp. http://www.performancetruckproducts.com/
I believe transferflo is the best tank out,I run a 50 gal crossbed tank fit under tanue cover gives me a total of 84 gallons,I have installed a ton of there tanks very easy to install and are the only ones that I know of that are DOT approved,Cross the bed tank uses trax system and replacement tank uses original sending unit,There kits are easy to install and work flawess been running one know for two years,Do your research it will lead you back to transfer flo,Good Luck
__________________ Mike
02 Duramax Black Beauty CrewCab,Long Bed,GT3788 Stage1 Garrett Turbo,Quadzilla Adrenaline Pulse Monitor,50 Gallon Transfer Flow Fuel Tank,5" Exhaust Turbo Back,AFE Air intake,Kenwood nav system
I have a 55 gallon tank in place of my stock one. I love it. can go 1,000 miles between fill ups.
where is this tank from ? brand and what not looking into some thing as well can if possible post some info on what it is you are using that would be great. If everone eals if possible give more detale on what there running to help us lookers out thanks and happy
Go to transfer flo.com
they have replacement tanks for stock tank or in the bed check out there web sight
O8 duramax i was thinking about the titian 52 gal replacement tank in stock location. Can this job be done with out pulling the box off. How hard of a job you think it would be. much info needed thanks.
Yes, a titan tank can be installed without removing the bed. installs in about 3 hours.
__________________ Brian, 19, 06 LBZ, EFILive, MM Diesel Performance, Alligator Performance, Suncoast, TTS, Cognito, High Tech Turbo, PPE, Magnaflow540rwhp/1000tq. 12.64/107.52
