| Premium Membership | |
02-26-2008, 08:58 PM
eBay Motors
#1 (permalink)
| | Senior Member
| 5th wheel hitch-goose neck ball? Can someone explain to me the advantage of a 5th wheel hitch over a goose neck ball. I have friends that use each. The guys that use the goose neck ball have a adapter hooked onto their 5th wheel campers. So there is nothing taking up bed space. There must be some advantage with the 5th wheel hitch in the bed other wise I would think everyone would use the goose neck ball to save space.
__________________  2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator |
| Advertisement
02-26-2008, 10:13 PM
eBay Motors
#2 (permalink)
| | Junior Member
| %th wheel hitches Hi, I have a Drawtite in bed 16K slider hitch. I have never had any problems with this setup, but it leaves the rails on the floor of the bed. That being said, if I was to do it again I would go with the B&W hidden turn over ball hitch. You would be able to go both goose neck and fifth wheel companion hitch and have a clear bed. Now to answer your question. The goose neck will be more ridgid with no side to side movement as a fifth wheel head would have foward/back/side to side allowing the trailer to absorb more movement and transfer less movement to the tow vehicle. I have heard plus and miniuses both ways, but I have had my best ride in the truck with the fifth wheel hitch. And even better when adding a air suspension to the trailer's 5th wheel pin box. I hope this will give some insight.
Jim
__________________ 2006 Duramax 2500HD CC SB LBZ 6 speed Allison, 2" Truxxx lift, 18"X9" Moto Metals, BFG AT 285/65/18, R-Fab Nerfs. |
02-27-2008, 04:12 AM
eBay Motors
#3 (permalink)
| | Diesel Performance
| I built a goose neck adapter for my 5th wheel. I like pulling on the B&W turnover because its one hitch no matter what I am towing, and pull the lever, flip the ball, and clear bed floor. Now, the 5th wheel is easier to hook up, as you slide into it as opposed to the goose neck where you set down over it.
__________________ We are very busy in the shop, please call for fastest service! |
02-27-2008, 07:21 AM
eBay Motors
#4 (permalink)
| | Senior Member
| Quote:
Originally Posted by Jimbolina's DuraMax Hi, I have a Drawtite in bed 16K slider hitch. I have never had any problems with this setup, but it leaves the rails on the floor of the bed. That being said, if I was to do it again I would go with the B&W hidden turn over ball hitch. You would be able to go both goose neck and fifth wheel companion hitch and have a clear bed. Now to answer your question. The goose neck will be more ridgid with no side to side movement as a fifth wheel head would have foward/back/side to side allowing the trailer to absorb more movement and transfer less movement to the tow vehicle. I have heard plus and miniuses both ways, but I have had my best ride in the truck with the fifth wheel hitch. And even better when adding a air suspension to the trailer's 5th wheel pin box. I hope this will give some insight.
Jim | Jim is sort of right here, but also a little off. The gooseneck hitch will allow the trailer pin to move forward, back, and side to side due to it being a pivot point. The hitch itself is rigid, yes, but allows full movement of the trailer king pin. That being said, their are fifth wheel hitches that move in all directions also, thus leaving less stress on the king pin of the trailer. I pull a 6-horse GN and a 36' 5ver. I'll try to be as short as possible here.....I had the Reese 16k 5th wheel hitch first and pulled my RV with that, but then got a GN trailer and had to get a GN hitch. I put the gooseneck adapter on the RV and thought it would solve the dilemma, but I was wrong, IMO. The RV jerked a lot more going down the road when hooked up to the ball, as opposed to the Reese. It just did not feel near as solid or stable as when hooked up to the fifth wheel hitch. I guess it depends on what you will be pulling the most. Horse trailers do fine on GN hitches...they are lower profile. But a 5th wheel is higher profile and rocks a little more going down the road due to the higher center of gravity...this being said, you will be happier with an RV hooked to a 5th wheel hitch instead of a GN hitch. If you are puling a horse trailer or flatbed, the Gn will perform very well. Hope this helps, sorry for the long explanation. All of this info backed with about 150,000 miles experience pulling both trailers coast to coast.
__________________ Byron
2005 liLLY 4x4..... ZF 6 Speed  , no muffler, lost kitty, Autometer C2 Pyro and Boost Gauges, EGR Blocker Plate, PCV Re-route, Resonator delete, By-Pass Dual Filtration, Amsoiled front to rear, Fumoto Valve, Texas Ranger CB.  proud to be an American!! 106,000 MILES and counting
1999 Park Avenue 36' 5ver
2002 Hart 6-Horse GN
2 Welsh Corgis and 1 Aussie Shepherd
02-27-2008, 03:16 PM
eBay Motors
#5 (permalink)
| | Duramax Forum Supporter
| I agree with byronbaumann. I have a B&W turnover and have pulled fifth wheels with an adapter. There is a lot of front to back jerking with the adapter opposed to the fifth wheel.
__________________ +2006 White Silverado LBZ, CC/SB 4x4, bully dog triple dog w/ outlook monitor, MBRP 4" turbo-back w/ 5" SS tip, S&B cold air intake, EGR blocker plate & fingerstick, DieselSite coolant filter, Transgo Jr. w/ Amsoil tranny fluid, blocked off turbo resonator
+Lowrance XOG gps, B&W turnover ball & Tow n Stow, 265/75/16 Hankook ATM RF10's, OEM style running boards, Husky floorliners frt/rr[/color]
+1 carseat in the back |
| Advertisement
