Old 03-01-2008, 07:53 AM   eBay Motors   #1 (permalink)
bcoldiron
Points: 260, Level: 5
Points: 260, Level: 5 Points: 260, Level: 5 Points: 260, Level: 5
Activity: 0%
Question 2007 LBZ Dually-Code P0401-Exh. Gas Rec.
Hey Guys, I'm new at this...so bare with me as I learn. I have a 2007 1 ton Dually that has 18,000 miles. Everytime I hook to the fifth wheel, I get the P0401 code. When I first got the warning light (check engine) I pulled into GM. they looked at it and told me the EGR timing was off and they reset and cleared the light. I made it about a 100 miles, and guess what... here it is again... To make a long story shorter, this continues to be an issue. I bought a Diablosport Predator and installed 4" exhaust. None of this helped the situation. Of course, All GM will do is keep resetting the Code. I just found this web site yesterday, and was wondering if the EGR Plate, might help my situation. I have worked with gas engines all my life... so this is new adventure for me. Any ideas would be appreciated.
bcoldiron is offline   Reply With Quote
Old 03-01-2008, 08:03 AM   eBay Motors   #2 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 6,686, Level: 34
Points: 6,686, Level: 34 Points: 6,686, Level: 34 Points: 6,686, Level: 34
Activity: 100%
BigRedChevy's Avatar
Is your exhasut turbo back or cat back? If it is turbo back you will need a "finger stick" to get rid of the code. The egr plat won't fix your problem but is always something good to put on, it will keep all of the soot out of your engine.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
Old 03-01-2008, 08:04 AM   eBay Motors   #3 (permalink)
BigRedChevy
Activity: 100%
BTW Welcome to the site!!!
KYLE
Old 03-01-2008, 08:12 AM   eBay Motors   #4 (permalink)
bcoldiron
Activity: 0%
Thanks for the Reply! It is a TurboBack. Now...I really got to show my ignorant's... "what is a finger stick"??
Old 03-01-2008, 08:15 AM   eBay Motors   #5 (permalink)
BigRedChevy
Activity: 100%
The fingerstick is a computer chip that you wire into you maf sensor to fool the egr into thinking there is enough flow.
KYLE
Old 03-01-2008, 08:25 AM   eBay Motors   #6 (permalink)
bcoldiron
Activity: 0%
Thanks! I'll get online and see if I can locate one. I'm in West Texas, small towns, so I have to order everything!
Old 03-01-2008, 12:51 PM   eBay Motors   #7 (permalink)
86burgandyss
Points: 1,828, Level: 17
Points: 1,828, Level: 17 Points: 1,828, Level: 17 Points: 1,828, Level: 17
Activity: 4%
Activity: 4% Activity: 4% Activity: 4%
86burgandyss's Avatar
Where can a "fingerstick" be bought at? Or is it a special order item? Csn newbee like myself install it fairly easily? i have the same issue as bcoldiron.
07 classic crew cab long bed
3.73 rear, stock tire size
86burgandyss is online now   Reply With Quote
Old 03-01-2008, 07:32 PM   eBay Motors   #8 (permalink)
dmax500
Points: 1,503, Level: 15
Points: 1,503, Level: 15 Points: 1,503, Level: 15 Points: 1,503, Level: 15
Activity: 17%
Activity: 17% Activity: 17% Activity: 17%
dmax500's Avatar
if the vehicle is still under warranty take the vehicle in to your gm dealer and ask them if the reprogram for the pcm applies to your vehicle gm had a prob with the egr system being to sensitive and the program will most of the time fix the issue.
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, edge box with monitor(soon to be in the trash! ),5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. saving up for SUNCOAST STAGE FIVE trans $1000 so far
dmax500 is offline   Reply With Quote
Old 03-01-2008, 09:46 PM   eBay Motors   #9 (permalink)
BigRedChevy
Activity: 100%
With the 5" turbo back exhaust and cai, i don't think the reprogramming is going to fix the code for him. If it is the P0403 then it will fix it, but not the 0401 and 0404.
KYLE
Old 03-01-2008, 09:59 PM   eBay Motors   #10 (permalink)
wildturkey_hunter
Points: 1,991, Level: 18
Points: 1,991, Level: 18 Points: 1,991, Level: 18 Points: 1,991, Level: 18
Activity: 0%
wildturkey_hunter's Avatar
I think you can get a fingers stick from Kennedy Diesel.
2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator
wildturkey_hunter is offline   Reply With Quote
