| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | |  |
03-05-2008, 12:24 PM
eBay Motors
#1 (permalink)
| | DuramaxForum Fanatic
| Egt's While towing, what should be a normal operating temp? I have seen mine rise over 1,000 before. Normally if I am pulling heavy it will hang around the high 800's. My temp sensor is after the turbo.
__________________ 07 classic crew cab long bed
3.73 rear, stock tire size
5% tint on all windows, and "eyebrow" on front windshield. |
| Advertisement
03-05-2008, 12:32 PM
eBay Motors
#2 (permalink)
| As long as you stay below 1350 you will be fine.
__________________ 07' GMC CC/SB Diamond Eye direct downpipe, 4" Mbrp DP back, Airaid CAI w/Amsoil dry filter and prefilter, fingered and blocked, Transgo Jr, UDP tie rod sleeves, Cognito braces, H2's w/285 BFG's, Airdog 150, EFI Live, Autometer phantom boost and pyro |
03-05-2008, 02:50 PM
eBay Motors
#3 (permalink)
| | Super Man Moderator
| I have mine straight piped and I hauled about 12,000 up a pretty steep hill. My EGT's went to about 1200 and stayed there pretty easy. However as GmcLbz said if you go over 1350 the aluminum heads will start to melt or warp at the least.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
03-05-2008, 07:21 PM
eBay Motors
#4 (permalink)
| | Member
Join Date: Dec 2006 Location: lower mainland, british columbia, canada
| ive got a 2005 LLY cc lb, i have the edge set on lvl 3 with and most responsive ( lvl 5), ive got a CAI and stock exhaust, i have got mine up to 1340 on an incline at about 75 % throttle. Is this fairly high for my setup?
I tow a trailer so when i put the edge down to lvl 1 or 2 when towing will my egt's drop?
I know i need to get a turbo back exhaust too, how much can i expect my egt's to drop from that? any other help would be appreciated, what you guys think?? |
03-05-2008, 10:29 PM
eBay Motors
#5 (permalink)
| | Duramax Forum Moderator
| a tip for the guys with the 6SP ally tranny,put it in manual mode and drop it into 5TH gear and your EGT's will drop by 200*'s almost everytime.
i have my probe on the driverside manifold and most hills i try to keep it belowe the 1400's,pulling 20,000+ with the PPE on the 300HP level isn't what you call smart.i wouldn't run over 1350 for more then a few minutes.
__________________ James
My Truck now,1987 Chevy 2500 350 tweaked,6" SuperLift,350 V8 bored 60 over,Elderbrock headers Cam and Titanium Rockers,750 Twin Pumped Holley Carb and some other goodies.crank dynos over 400HP. |
| Advertisement
