Old 04-08-2008, 10:35 AM   eBay Motors   #21 (permalink)
rock04max
Points: 1,233, Level: 13
Points: 1,233, Level: 13 Points: 1,233, Level: 13 Points: 1,233, Level: 13
Activity: 0%
Originally Posted by loubazooka View Post
Ditto that, why would you guys want to haul without it ? just asking ...I use it ALL the time when trailer is hooked up
likewise no matter what i hook up i use the t/h. I take of overdrive when im towing 16k or more.
04.5 LLY crew cab, PPE program, custom air box, 4in. turbo back exhaust, boost controller,AND A CUSTOM MADE fLYWHEEL/FLEX PLATE (ONE PIECE).
rock04max is offline   Reply With Quote
Old 04-08-2008, 12:16 PM   eBay Motors   #22 (permalink)
Ranger Ric
Points: 424, Level: 7
Points: 424, Level: 7 Points: 424, Level: 7 Points: 424, Level: 7
Activity: 0%
Ranger Ric's Avatar
I manage a State in Washington State and talk to alot of rv haulers, one of my camphosts has an 01 3500/allison set pulling a 16k moblie suite fifth wheel and got 10 mpg. I haul a 17foot toyhauler and with the Harleys and loaded for a trip it goes about 9k and I get 10 mpg. Has anyone else found the to be true or consistent. We do haul up here in the inland North West with many mountain passes, but once we are out of there it flattens out on ur trips even in AZ lately I got the 10 mpg. Yes I concur the T/H is a great invention, I use it running empty over passes in the snow and ice for downhill braking.
Ranger Ric
Assistant Pastor
Christain Crusaders Ministries
IFOC Chapalin
ABATE of Washington St Chaplain
2002 HD 2500 Durmax/Allison
Banks Monster/Stage 2 AFE Intake
1990 Custom Road King
If you drivin' one of those other things, "STOP IT"
Ranger Ric is offline   Reply With Quote
Old 04-08-2008, 12:18 PM   eBay Motors   #23 (permalink)
Ranger Ric
Activity: 0%
Ranger Ric's Avatar
Sorry,
I manage a State park not the entire State, wouldnt want that job.
Ranger Ric
Assistant Pastor
IFOC Chapalin
Old 04-09-2008, 09:01 PM   eBay Motors   #24 (permalink)
rock04max
Activity: 0%
Turbo's have a/r (air ratio) induction wheel measurements. The induction wheel puuls a certain amount of air then flattens out. If you go above the flat spot you will only burn more fuel because, the turbo can only pull a certain amount of p.s.i. Without going into lengthy dissc. you can put in perspective.
Old 04-09-2008, 09:33 PM   eBay Motors   #25 (permalink)
lubeman1969
Points: 975, Level: 12
Points: 975, Level: 12 Points: 975, Level: 12 Points: 975, Level: 12
Activity: 0%
I used the t/h mode this past weekend for the first time and willl agree it was great for braking and keeping the trans temp down. I was pulling about 5k through some very steep hills and passes in Murphy NC, got 10 mpg. I think some times it felt like it didn't want to downshift very easy, maybe it was "fighting " with my Edge controller?? The engine has no lack of power whatsoever, but maybe it would help to use the manual shift feature more often?
2006 2500 LBZ CREW CAB LONG BED
EDGE JUICE W/ ATTITUDE
315'S W/ 17" GEAR LOCKER 714C WHEELS
FABTECH 6" LIFT
BD EXHAUST MANIFOLD
S&B COLD AIR INTAKE
4" STRAIGHT PIPE EXHAUST
RESONATOR HOLE PLUGGED
1 CARSEAT IN THE BACK-
lubeman1969 is offline   Reply With Quote
Old 04-09-2008, 10:00 PM   eBay Motors   #26 (permalink)
daddysLBZ
Highway travler!!
Points: 6,295, Level: 33
Points: 6,295, Level: 33 Points: 6,295, Level: 33 Points: 6,295, Level: 33
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
daddysLBZ's Avatar
Cruise brakink not active in manual mode,I use it and never manual shift higher than about 2700 rpm's,seems to work well though..
Old 04-09-2008, 10:20 PM   eBay Motors   #27 (permalink)
daddysLBZ
Highway travler!!
Activity: 47%
daddysLBZ's Avatar
Like the way the T/H works,positive lockup of tourque con. Use it a lot when not towing to ease to a stop,or punish her a bit i.e. SMOKING PSD's OR CTD's,love the LBZ with allison!!!
Old 04-10-2008, 10:26 AM   eBay Motors   #28 (permalink)
Ranger Ric
Activity: 0%
Ranger Ric's Avatar
Rock04max
I am not up on how turbos work, are you referring to my 10mpg comment, if so is there a way to increase what the induction wheel pulls, resulting in higher fuel mileage when towing? Or am i way off base?
Thanks for your time on this, RR
Ranger Ric
Assistant Pastor
IFOC Chapalin
Old 04-10-2008, 04:06 PM   eBay Motors   #29 (permalink)
dieseldoc
Points: 234, Level: 4
Points: 234, Level: 4 Points: 234, Level: 4 Points: 234, Level: 4
Activity: 0%
I think using Tow/Haul is more important in the new LMM engines with the emissions crap. We all know when a diesel is "lugging" at lower rpms it does not burn the fuel as efficiently - thus the black smoke the older diesels and big rigs make. I know we all like to see that, but in the new engines with the DPF's this will just result in more particle build up and more regen cycles and thus worse fuel mileage. The T/H mode keeps the engine in a more efficient RPM range for cleaner burning and likely will lead to higher MPG overall. Not a mechanic but a valid point IMO.
08 GMC 2500HD Crew Cab Duramax 4x4 - all Stock
Fire Red with tow mirrors
dieseldoc is offline   Reply With Quote
