| Premium Membership | |
03-11-2008, 06:58 PM
eBay Motors
#1 (permalink)
| | Senior Member
Join Date: Feb 2008 Location: Alberta CANADA, and proud of it!
| Trailer Brake Controller & tow ball/hitch Hello everyone!
I'm in the market for a trailer brake controller and tow ball/hitch for my truck. I don't know what to look for so I'm asking for some basic information to get me started.
I don't own a trailer yet but that will come this spring. I plan to purchase a 20' Travel trailer, and possibly a 20' power boat. Both of which should be less than 7000# each.
Any suggestions are much appreciated.
Thanks!
EP
__________________ 2007 LBZ 2500HD LT2 CC SB 4x4 Red
Leer canopy, Aries Oval step bars, everything else stock.
Love this truck....HATE the fuel economy  yea yea, I know it's a truck, and YES I want the same mpg as a Civic
| Advertisement
03-11-2008, 07:06 PM
eBay Motors
#2 (permalink)
| | Member
| brake controller Tekonsha's are good, we have 3 trucks all with brake controllers on them, last one I got I bought it here, go with a more advaced one you'll thank me later Brake Controller
__________________ 2007 Silverado K3500 Crew Cab LT, 6 speed Allison,
Single rear tires, Long Bed, K&N CAI , Aero Turbine Muffler 3535 ( cool but not that great ).
Reason: typo
03-12-2008, 10:33 PM
eBay Motors
#3 (permalink)
| | Junior Member
| get a prodigy they are the best for the money...
__________________ 04.5 chevy duramax LLY 2500HD extended cab longbed 4x4 S&B Intake, silverline 4" exhuast and edge juice w/ attitude. |
03-13-2008, 06:16 AM
eBay Motors
#4 (permalink)
| | Member
| I have also heard the prodigy is the good one.
__________________ 2007.5 Silverado 2500HD LMM
S&B Air Intake System |
03-13-2008, 09:14 PM
eBay Motors
#5 (permalink)
| | Senior Member
| Quote:
Originally Posted by loubazooka Tekonsha's are good, we have 3 trucks all with brake controllers on them, last one I got I bought it here, go with a more advaced one you'll thank me later Brake Controller | I agree. I've had a few different brands but I liked the Tekonsha the best. The braking seems to be very consistent some of the cheaper ones tend to brake a little different some times to hard some times to soft. My horses tend to not want to get in the trailer after you slam them to the front of it a few times.
__________________  2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator |
03-13-2008, 09:23 PM
eBay Motors
#6 (permalink)
| | Senior Member
| Thanks for all the suggestions!
Are most of these controllers, plug and play? I mean, do they simply plug into the harness under my dash?
I don't want to do any special wiring work, so I'd like to buy something that installs easily.
Thanks again.
Love this truck....HATE the fuel economy  yea yea, I know it's a truck, and YES I want the same mpg as a Civic |
03-13-2008, 09:38 PM
eBay Motors
#7 (permalink)
| | Senior Member
| The Prodigy is a Teckonsha and yes it will plug in under the dash. Not exactly sure on the 07 but they probably havent changed anything. Why mess with a good thing ya know. They are really easy to install. Directions are pretty simple. As for a ball and hitch. I'd just go to a local farm supply store they will have anything you need. Just get a ball and hitch rated to handle the weight you intend to pull. Some of the balls are rated really low. For use with small trailers I suppose.
Bully Dog Power Pup
Plugged Resonator |
03-13-2008, 11:33 PM
eBay Motors
#8 (permalink)
| | Junior Member
| The Prodigy plugs in under dash. You might have to buy the harness (pigtail) with it. Its like 10 to 12 dollars. C world sells them. It was so easy to install it. It works awsome!
__________________ 2003 GMC HD CREW LB 6" RCD lift DBL hoops, Juice with Attitude, AFE Intake, ATS stainless exhaust, Mag Hitec tranny & Diff cover, PPE tie rod sleeves, Cognito steering support, Firestone air bags, B&W underbed hitch, Rhino lined, Kewood DVD TV, Viper autostart pager, 41 gallon tool box combo.
JUST DUNE IT !!! |
03-14-2008, 12:03 AM
eBay Motors
#9 (permalink)
| | Junior Member
| Tekonsha's are good, I have one and I like it. You have to look at what your buying though a friend of mine bought a fancy, expensive controller and found out later on after alot of BS, that it wouldn't run electric over hydrolic brakes, now that controller has a fancy place above the bench and he got a tekonsha. You also need to be aware of the number of axles your running some controllers only do 1-2 axles. My tekonsha- voyager handles 1 to 4 axles, is easy to install and use, comes with a video on set up, the harness should be already hooked up under your dash (wrapped up) just plug it in, You'll probably have to buy a fuse and put it in for aux brakes, square type, think about 40-60amps Located in fusebox under the hood.
__________________ 2005 duramax, LLY,2500HD, 4x4, drop diff kit, 33x12.5 pernely jones, and stelth winch bumper, Next is a 5" cat back and maybe a Hypertech Power Programmer ??? |
03-14-2008, 04:26 AM
eBay Motors
#10 (permalink)
| | Member
| Quote:
Thanks!
EP | When buying a draw bar and ball. I would only use a solid draw bar and I would over kill on the ball. I bought the heavest rated I could. You just dont know what you might be hooking up to in the future. Why buy twice
__________________ 06 GMC Crew cab LBZ
PPE Excelerator & Boost controler
Magna Flow SS 4" with 5" tip
EGR Block & fuel rail shim kit
Auto Meter lumna Boost Pyro Trans on the pillar
Trans Go Jr.
Leveling kit, Bed Cover, 5" nerf bars looking at 19.5 |
| Advertisement
