I know I have seen post on these, but can not find it. I am wanting to get a set for my truck. How much and what systems do you guys have? Is it an easy do-ityourselfer, or would it be easier to have a shop do it? Thanks for all your help.
__________________ 07 classic crew cab long bed 2wd
3.73 rear, stock tire size
I have it and it easy to install. Only cost me $150, that only the bags. You really dont need to adjust the bags that much and if you do go to a gas station and use there hose. I would say this is one of those things that is better then the add a leaf and other crap like that. You buy the bags and you will be happy.
__________________ Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd Omaha Truck and Trailer offering Woodworth custom build trailers. Now a factory authorized Whelen dealer
My iron is yellow
10,000 lbs firestone bags installed 350.00 at my local les schwab
__________________ 05 crew cab short box.lly ally.airaid cai.mbrp 4 inch cat back exhaust.granatelli big g 90 hp tune.off road unlimited leveling kit.285 75 16's firestone air bags.
Also would I run into any fitment problems being I have a 5 inch exhaust?
I couldnt see it being a very hard install you should also be ok with your 5inch exhaust.
I would have to say spend the extra $$$$ and get the compressor so you can fill it up while your driving. Especially for what you do if you happen to get a heavy load and the truck is sagging you can adjust it in the cab. A friend of mine just bought a truck with the system in it. Its definatly a nice idea.
Yea I would like to, but extra money around here is like finding a 25 year old virgin, not gonna happen. I am just getting back to work from a knee injury., was off work for 2 months
My brother in law got me a kit (just bags, no compressor) in Salt Lake City for $250. I installed them in my garage in two hours with no special tools. On thing I did differently was to get a "T" fitting so both bags filled from one valve rather than the two that came with the kit. 2 years and no leaks. I run 70 - 75psi with the 5th wheel on, 5psi without.
I run these in my truck as well. I actually installed these in my 04 gasser then swapped them into my 05 Duramax. I'm not sure on 07's but the classic and older is very easy to install. You just remove the bump stops and the bags bolt in it's place. The only drilling was for the air fittings. I installed two seperate fills. I have a large Lance slide in camper and needed sway control. With one fill valve air will shift from side to side. I guess with a fifth wheel being in the middle of the truck that wouldn't matter much? I run the same pressures as Blastmeister does. 5 psi w/o camper and 65-75 with my slide in camper. Put your fill valve in either the gas cap or like I did, In the drivers side wheel well. towards the front of the truck. 2 trucks and 4 years with no leaks. I don't have a compressor. I fill them at home or any gas station.
__________________ 2005 GMC 2500 HD SLT EC s/b
Banks Big Hoss bundle
Firestone air bags
315/75/16" Firestone Destination A/T's
Leveling Kit/ Bilstiens
Western Pro snowplow
