Using the "M" on the Allison Transmission - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 05-18-2008, 01:36 PM Thread Starter
Ok, I am new to the diesel truck and the Allison Transmission. I see that the M is used when pulling a trailer. My question is When is the most appropriate time to use this feature. I will be going to Colorado in June and will be crossing over Cinnamon Pass that drops into Lake City. I have been told by most folks that once you go down this pass you will not want to go down it again. I am thinking that this is purpose for this feature. I can use all the help I can get concerning towing my 5th wheel through the mountains and how this feature can help.
Thanks
2007 Duramax LB with Old body style
No modifications at this time
Roughly 20,000 miles
Duramaxcop is offline
post #2 of 9 (permalink) Old 05-18-2008, 01:39 PM
Super Moderator
BigRedChevy's Avatar
Most of the time Tow/Haul mode will do everything that you want it to do with the grade braking feature. If you wanting to put it in M mode to hold a gear longer then it wouldn't hurt a thing. The allison is a very smart tranny and will take care of itself, if you put it in M4 it won't let it over rev it will shift to 5 before it hurts anything, so i would say put it in tow/haul and take it easy at the top.
Welcome to the site!!!
BigRedChevy is offline
post #3 of 9 (permalink) Old 05-19-2008, 07:12 AM
fenmor's Avatar
M - is for manual
I tow a 5 th , and personally I dont find too many times that I need the manual control or the tow-haul mode .
Going through the mountains here in British Columbia , I will use the tow-haul mode when going up a very steep grade for some distance or use it when going down a steep grade where brakes alone may heat up.
You will love the Allison trany , its the only auto to have in a tow vehicle . ( or stay with a standard )
fenmor is offline
post #4 of 9 (permalink) Old 05-19-2008, 07:28 AM
Save Water, Drink Beer
Landscapeman's Avatar
I tow a large trailer most of the week and I have never had to use M. Tow/Haul mode takes care of everything. Good Luck and Welcome.
2006 GMC 2500HD LBZ Crew Cab 4x4, Tie Rod Sleeves, LineX, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
1987 Corvette
Crazy Larry. Get it Here.
http://www.mediafire.com/?g3mtmmjogkz
Landscapeman is offline
post #5 of 9 (permalink) Old 05-19-2008, 07:36 AM
pONSi's Avatar
I was towing in "M" mode this past weekend...I used this mode in windy hilly roads where I knew my speed would be changing quite often...In my situation I felt there was no reason for my tranny to shift into 5th or 6th gear during this time because before I knew it I was decellerating down to 2nd gear so I set it in "M" 4...This just prevents it from shifting between gears so much which I think is easier on the tranny
pONSi is offline
post #6 of 9 (permalink) Old 05-19-2008, 10:57 AM
Diesel Addict
the only time i used M mode is when i was running heavy roughly 25,000-30,000 pounds gross weight so on the hills i put it in M mode and shifted to 5TH gear to keep my EGT's down since i was running aftermarket HP.
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline
post #7 of 9 (permalink) Old 05-21-2008, 12:31 PM
07blkLMM's Avatar
Even though I have only towed my TT once, I used the M when I was decending a steep winding grade on a mountain road that I didn't want to get over 20 mph on. Otherwise, I just used T/H on the main roads. It works great!
07.5 Black Chevy Duramax LMM. Westin Nerf Bars, Undercover bed cover, otherwise stock.
07blkLMM is offline
post #8 of 9 (permalink) Old 05-28-2008, 08:29 AM
TomK's Avatar
I live in Colorado and tow my 5th wheel in the mountains allot. I've found the T/H works great 90% of the time, automatically down shifting and applying the engine break on the down hill side of the passes. I use the M mode on the steeper, windyer roads that I feel I need more control on. I've descended many long steep grades by toggling up and down through the gears without having to use my brakes. It makes for a safe and comfortable decent.
TomK is offline
post #9 of 9 (permalink) Old 05-31-2008, 01:53 PM
linzer truck lines inc
hotshottrucking is offline
