How Heavy Do You Pull With Your 2500? - Chevy and GMC Duramax Diesel Forum
 22Likes
post #1 of 88 (permalink) Old 08-08-2015, 01:19 PM Thread Starter
So Im in the market for a 5th wheel toy hauler and the smallest I could find is the Raptor 300MP which has a dry weight of 13400 and a pin weight of 2600. My 2008 is rated at 13600 and a pin weight of 2800. Im not going to haul any toys. I got air bags already and Im looking to install a tuner with an exhaust break.
So how heavy have you towed to where you can say you felt safe and comfortable.
Kojak is offline
post #2 of 88 (permalink) Old 08-08-2015, 02:25 PM
There is a picture thread in the towing section with some 3/4 tons pulling a few big trailers. Not sure the specs. Ive got a 6000lb TT, so no help here.
2005 GMC SIERRA 2500HD 4X4 CC SB w/ Idaho Robs Tune, CTS2, 265/75 LTX M/S2s, B&W turnover ball w/ Andersen Ultimate Hitch, Rancho 9000XL's, MBRP 4" DP back w/ muffler, LBZ mouthpiece, AirLift 5000's, RDS 60G combo tank.
2014 Grand Design Reflection 337RLS (10,500lbs dry)
Zac808 is offline
post #3 of 88 (permalink) Old 08-08-2015, 02:51 PM
bpe1's Avatar
Towing power is never an issue. Pin weight is concern with 2500.
2006 Freightliner Century 120 with Detroit Diesel. Sold my 2012 Chevy 3500 dually work truck with CM ER hauler bed and EZ Floater air hitch. Towing 2003 Teton Grand Freedom 5ther weighing 20,890 lbs. Traveling the USA welding pipe, repairing plants, building new ones & really enjoying God's beautiful country.
bpe1 is offline
post #4 of 88 (permalink) Old 08-08-2015, 10:25 PM
handirifle's Avatar
Well very FEW ever tow at rated dry weight. Your 2500 is only rated for 200lbs over dry weight? I say you are asking for trouble with that much weight. It's not the power, but brakes, suspension, stability, oh yes that legality issue.
Now my next question is, If you are never going to haul toys, why buy a toy hauler? If you insist on hauling that much trailer, sell the 2500 and get a 3500, problem solved.
JimmyD and RickV like this.
2006 GMC 2500 4x4, CCSB
LLZ, 6 Spd Allison
KYB Monomax shocks
Firestone Ride Rite Air Bags
AutoMeter EGT and boost gauges
handirifle is offline
post #5 of 88 (permalink) Old 08-08-2015, 10:31 PM
handirifle's Avatar
For the record, when I bought my 2500, I decided to stick well under the tow rating. My trailer is rated 12,700 GVWR and it's usually towed under 12K, usually closer to 11. Just came home from Wishon Village campground, north of Shaver Lake at 7,000ft elevation. The climb up on the way to it, and subsequent decent on the way home involves a 10 mile grade as steep as 11% at times, and the truck handled it with aplomb. I was holding 47 MPH on the way up at 1200 deg EGT's at 2200-2300 RPM.
LLZ, 6 Spd Allison
KYB Monomax shocks
post #6 of 88 (permalink) Old 08-09-2015, 06:48 AM
FarmerJon's Avatar
My gross was 17000 pulling a loaded 32 ft 5th wheel.
07 classic LBZ crew cab long box. Bone stock and staying that way. For now.
FarmerJon is offline
post #7 of 88 (permalink) Old 08-09-2015, 07:56 AM
bpe1's Avatar
I see no problem with a 2500 as long as you are within limits of your axle and tires. Also pin weight on campers is always more than advertised. There is also a huge storage forward the axles on a 5ther.
bpe1 is offline
post #8 of 88 (permalink) Old 08-09-2015, 10:33 AM
HDBOWTIE13's Avatar
Heaviest I pull I'd say is around 15-16k, double anhydrous tanks. Only pull the tanks a couple times tho. And I don't normally go over 25 to 30 mph. Then I'll pull a mini sometimes and I think total it and the trailer is around 10k to 12k. Maybe a bit more. These are never long distances tho and the truck never has a problem.
SOLD: 06 Silverado 2500HD LBZ LT3 4x4
99 Silverado 1500 classic 4x4 111k
05 AC Firecat F6 Sno Pro
HDBOWTIE13 is offline
post #9 of 88 (permalink) Old 08-09-2015, 01:51 PM
bfaucett's Avatar
15k off the bumper with over 2k on the hitch (pintle) and 14k actual weight fifth wheel with about 2500 pin
'15 Chevy ccsb wt wehrli | motorops | xd | nitto | atta | curt | tork lift | airlift | edge | s&b |
Bought 11/21/14 72 mi
01/01/16 177685
'03 cc lb drw bd intake, intake horn mod, dsp5, 4" silverline turbo back, d-celerator exhaust brake, amsoil bypass, amsoil synthetics throughout, 225/70 19.5, 1/3 drop, oil cooler
Traded at 299,465
bfaucett is online now
post #10 of 88 (permalink) Old 08-09-2015, 02:33 PM
My trailer is 15k fully loaded but i sit around 13,500 to 14k most trips. Tows it like a champ.
2010 GMC SLE 2500HD 4x4 White CCSB 33 TOYO AT2's Method Racing Wheels Kryponite A-arms - Kryptonite sway bar ends Rare parts tie rods Moog Idler & Pitman arms - Cognito PISK - Fox 2.0 shocks McGaughty drop shackles Edge Insight EAS and backup camera PPE modded air box MBRP 4inch DPF back Line-X Amp steps Fumoto valve Firestone towbags w/ compressor JL10 sub and amp - Katzkin leather seats - Filled with Amsoil
GMCRIG is offline
