I have lifted my truck and built up the tranny axle, etc. I wanted a monster hot rod. However, I don't want to lose the capability to tow when needed. I have toys and haul a 30' boat at least once or twice a month. I would say I tow about 7500lbs. However I may upgrade to a 12000lb boat. Will my truck be fine?
__________________ 8" Fabtec, 22" Wheels, 37" Toyos, Airaid, PPE Hot +2, Dynatra 80, 4.10 gears, ATS stageII Trns, air bags, mbpr 4" dpf delete
I honestly wouldnt think you should have too much trouble. Obviously you wouldnt want to rod the piss out of it, but the same would be said if you didnt have a lift in it. One of the main places you can lose drivetrain strength on a lifted truck is the u-joints. If your pinion angle is too extreme the u-joints are stressed quite a bit more than they would be if you were at stock ride height.
__________________ 2001 Club Cab 2500HD 4x4 D/A
Banks 6 Gun with speed loader, Diablosport Predator for speedo correction, PPE boost valve, PPE lift pump (soon to be installed), Grille guard, Moon visor, Leveling kit, 285-75-16 A/T TA's, Grand Rock stacks, spray in bed liner
1993 Z28 M6
Lloyd Elliot ported heads and intake, LE 1.6 cam, 1.6 RR, 52MM BBK TB, 30lb/hr injectors, PCMforless tune, K&N FIPK, Pacesetter longtubes, Pacesetter ORY, Magnaflow catback -the cat Dynaspark billet optispark, RAM kevlar clutch, 275-45-17 pirellis on 17x9.5 ZR1's up front, 315-35-17 on 17x11 ZR1 rears
towing with a lifted truck has lots of varibles and the reason i say that with a taller lift you run into what 01Dmax said,next question the suspension you have does it handle weight like the stock one and i see you have airbags so that helps.also will you be towing a bumper pull trailer or a gooseneck i'm guessing bumper pull since with the lift it would be next to impossilbe to use a gooseneck.
__________________ James
I HAVE THE MEDAL
Ya I'd say the drive train and everything would be ok. It just might get alot of sway. As TYREBOYZ_DEMAXIN your truck wont hold weight anymore like a regular truck! You might want to look into getting a weight distribution hitch. That could help with leveling out the weight.
