| Premium Membership | |
07-23-2008, 08:05 PM
eBay Motors
#1 (permalink)
| | Junior Member
| 05 tow mirrors on a 01? i bought some of the power extending tow mirrors off of a 2005 2500 and i want to put them on my 2001 3500, what is needed to get the power extend to work? my 2001 came with the regular power heated mirrors. thanks |
| Advertisement
07-23-2008, 09:20 PM
eBay Motors
#2 (permalink)
| | Catch Me If You Can!
| I think you will have to go to the dealer and have your BCM flashed to make it work. Mine you have to have the mirror select switch in the middle/neutral, and then push the mirror adjustment button to the left to extend and the right to retract.
__________________ KYLE
07-23-2008, 10:16 PM
eBay Motors
#3 (permalink)
| | Junior Member
| what about the wiring required to make it work? |
07-23-2008, 10:19 PM
eBay Motors
#4 (permalink)
| I don't know about that, i know the 07classics will work on the 05s. I am not sure about the 01s though. IIRC all of the wiring and plugs are the same from the 01-07 classics.
07-24-2008, 04:27 AM
eBay Motors
#5 (permalink)
| | DuramaxForum Veteran
| I do not know on yours but I put the extendable towing mirrors on my work rig and was dissapointed when I did not find a plug for the LED blinkers in the mirror. Yours may have a similar problem with the buttons not being capeable of extending the mirrors. I would look to see how much a whole new switch assembly for the door would be.
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE |
07-26-2008, 08:07 AM
eBay Motors
#6 (permalink)
| | Senior Member
| you need the entire door control, you may also need to add a hot for the turn signals and power out feature.
__________________ 06 LBZ 3500 4x4 single rear wheel regular cab long bed WT. PPE economy, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxs. work in progress |
07-26-2008, 09:53 PM
eBay Motors
#7 (permalink)
| | Super Man Moderator Points: 10,685, Level: 44 |
| Ya it might be alot of work. Im not a wiring expert but you might be better off wiring the extended mirrors seperatly and have them work off a switch.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
09-18-2008, 04:21 PM
eBay Motors
#8 (permalink)
| | Duramax Lifetime Supporter
| if your stock mirrors were power folding the mirror switch just needs to be switched out with the switch that came with the tow mirrors.
Oh and also looking for the telescoping tow mirrors that came on the 05-07 classics.( the mirrors that look like ford tow mirrors) |
09-18-2008, 06:16 PM
eBay Motors
#9 (permalink)
| | Member
| So with my 05, i have the power adjusting tow mirrors, and i wanted to go to the new big tow mirrors, should just have to switch out the mirrors themselves and plug in?
__________________ Derek W.  Kenworth Diesel Mechanic
2005 Chevrolet Silverado 2500HD
6.6L, 28,000 miles, B&W fifthwheel, PacBrake airsprings |
09-18-2008, 06:24 PM
eBay Motors
#10 (permalink)
| | BigDaddyDiesel
| IDK but you are all pretty lucky, I asked the dealer about ordering some for my '03 and they told me that the '03 was the only year that they could not get all of the power options to work like the other years...
But now I am buying an '02 to haul with so that may solve my worries... |
| Advertisement
