towing capacity on older 2500 - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 06-07-2011, 06:50 AM Thread Starter
I have a '01 2500HD Duramax. It has 200000 miles and the former owner hauled horses with a gooseneck. I would like to get a flatbed gooseneck with a GVRW of 14000lbs (appx 20-25ft). I would like to use it for some light local hauling. I don't plan on maxing it out very often.
Would it still be safe to pull 10000-12000lbs loaded on a regular basis? I know some powertrain and suspension mods will be necessary down the road but for now it is stock.
I need to know if it is worth my time and money to invest in a trailer and all the PennDOT regulations first.
Any suggestions will be greatly appreciated.
smoker01 is offline
post #2 of 8 (permalink) Old 06-07-2011, 07:45 AM
jbrown1132's Avatar
welcome to the forum! Heyyaa
take a look at the sticker located inside your truck's driver side door jam, that is what the PADOT will be using as a guideline for the truck and loads, especially if you are going to be inspected.
imo, you'd be better off with a bigger truck, or a smaller trailer and load. i know the truck can pull it and all that good jazz, but it sounds like you may be state which the DOT may give you some trouble with too much loads on trucks. it would be best to check with your state's law regarding the your truck for buisness to see if you need special DOT numbers as well.
i hope this may help, good luck
'05 GMC 2500HD (white) slt cc sb 4x4
efi-tuned by idahorob, egr blocked, pcv rerouted, lift pump, kodiac mp,autometer sportcomp gauges, turbo dp, 4" ss magna flow exhaust straight piped, firestone ab, kool-vue towing mirrors, 5th wheel hitch with slider, gooseneck hitch.
305 MT ATZ's on eagle alloy 17x10
jbrown1132@yahoo.com
alligatorperformance.com
atptrucks.com
Truck is sold....
jbrown1132 is offline
post #3 of 8 (permalink) Old 06-07-2011, 08:16 AM Thread Starter
thanks jbrown.
I agree a larger truck would be ideal but for now this is what I have. I am still making payments on the '01 and am not in a good enough place to buy a bigger truck.
I am trying to stay under 26000lbs so that I don't need a cdl. PennDOT is really strict and I know I will have to register it and run a log but am trying to do everything I can with what I have. If I can make a go of this then a 3500 dually will be next.
My biggest concern is can an older truck with high mileage handle loads close to its max rating?
smoker01 is offline
post #4 of 8 (permalink) Old 06-07-2011, 09:01 AM
jbrown1132's Avatar
smoker, with good vehicle maintenance, your truck will do fine. i would suggest a good efi tow tune from a well known tuner, you don't have to spend alot of money, you could buy a pretuned ecm or a dsp 2 or dsp 5 switch with adjustable tunes. the reason i suggest this is with a tow tune you can get the turbo brake which is great while towing, you will be glad to have that when your towing those loads. the extra power and torque is good as well.
my truck is a totally different machine with efi! do some research and you will find it is the best to use especially for towing.
atptrucks.com
Truck is sold....
post #5 of 8 (permalink) Old 06-07-2011, 09:19 AM
if you are inspected by any DOT officer, your gross vehicle combination weight rating is the weight you cannot exceed. Unless the truck or trailer is registered at a weight either higher or lower than stickered, then that is what you'll have to go by.
If your truck is stickered at 9900lbs and your trailer is stickered at 10,000lbs your gvcwr is 19,900lbs. Don't exceed that and you'll be fine. I wouldn't go much over 20K with my combo weight, but thats me.
2007.5 White SBCC 4x4
MBRP 4" Turbo back dump exhaust|EFI Live|Edge CTS Insight|EGR Blocked|DE Down Pipe| Air Lift Air Ride 5000|Leveling Keys|
Bilstein 5100|Kubota GL1100 Low Boy Generator W/D722 Diesel
My Company - www.relienteti.com
RossThompson is offline
post #6 of 8 (permalink) Old 06-17-2011, 08:48 AM
Trailer weight
Followiung that ....I have a 2005hd duramax 6.6 crewcab. Wanted to purchase a larger alum. horse trailer...
fully loaded GVW of 14,000 lbs. and an empty weight of 11,720 lbs. Would hauling this trailer require a 3500hd since trailer+truck wt is over 22000?
Thanks in advance for any input. Also the specs on a 3500 are not much diff than a 2500hd. what gives there?
bub549 is offline
post #7 of 8 (permalink) Old 06-17-2011, 09:07 AM
Ur lb7 dmax will haul about anything u put behind it and 200000 miles that truck if it was maintained regularly still has lots of life left of heavy towing and lead footed driving
Bone stock 2012 cclb dually 4x4 LML - Sold 05 lly 6in rcd, 4in straight pipe, banks ram air, efi live, afe mp,20in moto metals,35 12/50 toyo open country mud terrains , mag hytec pans, di pricol boost and pyro gauges, and 149xxx and counting-was a great truck
duramaxen is offline
post #8 of 8 (permalink) Old 05-03-2013, 09:24 PM
Is there a chart for what a particular truck will haul and tow.
Bob Shelton
Red 2006 Sierra 2500HD LT LLY
Bone Stock except for Hushpower muffler and K&N Air filter
Bulldog48 is offline
