Old 10-02-2008, 04:29 AM   eBay Motors  #1 (permalink)
trans clicking while shifting into park
When i come to a complete stop and shift my trans into park sometimes it will make a clicking sound like a normal trans makes if you shift into park while its still moving this has happened several times in the last couple of months and does not sound good
please help
thanks
RED 01 chevy 3500 crew cab 4 wheel drive
LB7 duramax/allison 5 speed straight pipe
FLIRTIN' WITH DIASTER
noshowjones is offline   Reply With Quote
Old 10-02-2008, 09:23 AM   eBay Motors  #2 (permalink)
Super Moderator
BigRedChevy's Avatar
Mine does it all the time. Does it also do it when in reverse backing up? Mine as done it since new and continued to do it after the re-build.
KYLE
2010 Camaro SS LS3 426 HP
Old 10-03-2008, 05:56 AM   eBay Motors  #3 (permalink)
fliud is fine no other issues just come to a complete stop and shift trans into park it will make a clicking sound that probably last 2 or 3 seconds really loud does not do it all the time just ever now and then
sounds like that cant be good
thanks
Old 10-07-2008, 10:06 PM   eBay Motors  #4 (permalink)
ufreak's Avatar
mine has done since it was new as well. and i do a lot of stop and go at work its in and out of park alot, its lasted 40,000 miles so far.
2007 gmc 2500hd k&n cold air intake, 5'' turbo back exhaust no mufflers, ppe boost controler and edge juce with attitude.
ufreak is offline   Reply With Quote
Old 10-12-2008, 02:52 PM   eBay Motors  #5 (permalink)
i can also make it do this in 4 wheel low shifting from drive to park park to drive
Old 10-12-2008, 05:17 PM   eBay Motors  #6 (permalink)
LetzRock's Avatar
My stock 2004.5 does the same thing in low lock.
LetzRock is offline   Reply With Quote
Old 10-12-2008, 06:00 PM   eBay Motors  #7 (permalink)
D.W.'s Avatar
It could be your locking powl getting worn, it the locking mechanism in the allison that puts the truck in park and stops it from moving.
2005 Chevrolet 2500HD crewcab LLY, LT3 package
Banks 4" Monster Exhaust, S&B cold air intake, Kodiak mouthpiece and MBRP cat delete pipe
B&W turnover ball, Pac-brake air springs
BF Goodrich All-Terrains 285/75/R16 on stock rims
Mods to come:congnito tie rods, and PPE Excellerater Standard
D.W. is offline   Reply With Quote
Old 10-12-2008, 07:00 PM   eBay Motors  #8 (permalink)
Durallymax's Avatar
In Low I think all of our trucks do it.
I would say its just getting worn.
It not always as bad as it sounds. Just run it till you dont have park . Kidding but if you had a shop replace it it will be expensive.
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Videos Here
And Here
Vinny
Durallymax is offline   Reply With Quote
Old 10-13-2008, 07:52 AM   eBay Motors  #9 (permalink)
If the park pawl is wearing you will know it. The park pawl on these transmissions is fairly large as are the notches it engages. Also, you have a spring wedged into the case to pull the park pawl back when the park rod disengages.
I don't really have an answer for the clicking other than maybe its all the solenoids in the vb releasing.
Diesel Nut is offline   Reply With Quote
Old 10-13-2008, 08:58 AM   eBay Motors  #10 (permalink)
bigdaddydiesel's Avatar
I have had 12 GM trucks since 2000 and all of them have this problem, not just with the Allison... I would also check the gear lube in the differentials, and in the transfer case, if they get low or have never been change and are dirty they can cause this too...JMHO
Chris Kelley Does not like the new format one bit, please change it back.
'03 GMC 2500HD 4x4 extcb sb sle
AMSOIL Direct Jobber ZO # 1678239
Toll Free (888) 563-5143
email
Become A Dealer
Online Catalog
