Duramax Diesel Manual Transmission Problems? - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 08-17-2011, 03:21 PM Thread Starter
Looking at a 2005 Chevy 2500 hd duramax (6.6l) with 130K miles. i'm told that the "allison eats up manual transmissions" and that i should only buy one with an automatic transmission. What are the problems with the manual transmission and should i, in fact, avoid buying one?
chevy lover is offline
post #2 of 12 (permalink) Old 08-17-2011, 03:27 PM
saw what you did there
theunderlord's Avatar
"the Allison eats up manual transmissions"
1. the Allison is the name of the automatic transmission.
2. the ZF-6 is the name of the manual transmission, not made by Allison.
3. You need to forget anything that any "expert" or "diesel guy" has ever, or will ever tell you.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 12 (permalink) Old 08-17-2011, 03:37 PM Thread Starter
sooo, no problems then??
post #4 of 12 (permalink) Old 08-17-2011, 03:38 PM
Nope.
post #5 of 12 (permalink) Old 08-17-2011, 03:41 PM Thread Starter
sooo, this truck does not have an "allison transmission" because it is a manual? still just as durable as an allison? other advantages to an automatic transmission over a manual in this case? thanks for your input!
post #6 of 12 (permalink) Old 08-17-2011, 04:08 PM
are you high?
post #7 of 12 (permalink) Old 08-17-2011, 04:15 PM Thread Starter
not high...just young and inexperienced. trying to get some straight answers and some good advice from the "pros". i'll try to find one somewhere else...
post #8 of 12 (permalink) Old 08-17-2011, 04:30 PM
Don't know how more clear I could have been... but that's the internet for ya.
There are no inherent problems vs one or the other.
The ZF-6 equipped trucks are harder to find, and are no longer made after 2007.5.
post #9 of 12 (permalink) Old 08-17-2011, 04:36 PM
JIB 07's Avatar
The automatic transmission is made by allison..its the brand name. The manual transmission is not made by allison
2007.5 Chevy 2500HD ccsb Duramax/Allison, victory red, 4x4, Quadzilla stealth 2 with MBRP 4" staright pipe DPF deleted, EGR blocked, GLowshift LED EGT gauge, Top gun 2.5" levelling kit, Overload springs on rear. 18X9 Ultra Mavericks wrapped with 295/70/18 (34.3) Nitto Trail Grappler MT's. Bilstein 5100 series shocks, Spray in bed liner, B&W flip ball gooseneck hitch.
JIB 07 is offline
post #10 of 12 (permalink) Old 08-17-2011, 04:41 PM
WishforaDMax's Avatar
And there u are showing ur age. The zf6 is a good transmission and will handle the power if u prefer it over a automatic. This isn't the 1950s anymore automatics can handle power now as well. The Allison is a grade a example of a good automatic tranny and u will not have any problems with going with the Allison
Names Yezin im 24 and yes i bought my truck myself
2006 CCSB 2500Hd Lt2 LLY DMax, Efi live 150hp Idaho Rob , 5in Straight Pipe 6in Black Tip:rockin, Diamond Eye Dp, Tie rod sleeves, Edge Insight cts, SDP Egr Delete Pipe, Fprv shimmed, Pcv Reroute, All On mod, Blue led's in gauges cluster, Clarion Nx700, 8000k HID's highs/lows/fogs, Rbp Locking Fuel Door, Recons with Led Reverse lights
Name is Sharks06LLY on Duramaxdiesels.com
WishforaDMax is offline
