would you say a suncoast stage 3 then, the wife will be pissed seein as i paid cash for the truck a week ago, but if its necesity i might have to go ahead. what kind of cost installed for a stage 3/4 roughly?
__________________ 2007.5 ECSB LMM
6" Fabtech Lift
5" MBRP Turbo Back W/6" Tip
Quadzilla Stealth 2
More to Come
I turned my Diablo up to 120 when I did my transgo and I have not had any problems with slipping or going into limp. I let the trany re-learn and then I hammered it a couple times and boy-oh-boy. I do not know about 135 but 430 hp to the tires is enough for now. Lord Knows what kinda torque I'm runnin
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
I just had my transmission serviced so i drained my fluid into a clean bucket and put a lid on then when i was done i still came up 1 quart low. The only problem i had was the two solonoids popped out and rolled and they look alike enough that i could not tell them apart i reassembled and figured i had a 50/50 chance they were wrong. So far no problems seems to be doing fine after 1000 miles.
__________________ 2007.5 LMM, quadzilla stealth 2, mbrp turbo back 4" cool duals, aem brute force cold air intake, egr block, transgo jr.
When I put the kit in mine, both o=rings were green. The solenoids didn't look any different, but the spools are.
Took approx. 9 1/2 qts. to top off. 6sp. claims are that it can hold another 125-140 hp, not sure if it's the same for the 5sp. I would think so since they're both A1000's.
as I stated it does nothing for the 5spds. They have different valvebodies.
where are you guys paying $120 for them.
The place where I order them from charges $80 shipped.
'03 GMC 2500HD LB7/Allison EC/SB 4x4 Dark Charcoal Metallic SLT. Injectors at 84,000. Sled Puller/DD EFI Live: V7.5.5/V8.1.2 OS:03904405 Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
Many mods to come over the winter.
no kidding im in canada ,and it was 75 $ for mine. i drive in manual 4 and tow haul all the time for almost a year and a heavy foot from hell,on level 5 and she feels good ,, time will tell
__________________ 2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
IMHO I wouldnt waste my time on a stage III unless you are absolutley positive you wont want to add tons of power to the truck. Like our farms 02, Im looking at thorwing in a Stage III because I know it will never get anything more than a stock LB7 Cp3 can flow.
The Stage IV is a little more money but once you do it, your done.
I know Eric Merchant Charges $4500 for a stage IV with a 1054,55,57,58,59 converter and 200 bucks less with a 56. He will pull it out build ip up and put it back in for that price. and he can do it very fast.
Otherwise your looking at roughly 3000 bucks for the stage IV with any converter besides the 56. The 56 is again 200 bucks cheaper. Also note the $300 core charge.
512rwhp 1085lb-ft
13.6 @ 99mph
