Broken transfer case - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 02-14-2012, 02:32 PM Thread Starter
Fcaramadre's Avatar
Unhappy Broken transfer case
I posted already on here when I thought I blew a tranny line, But it was a lot worst than that so I decided to repost what happened. I was driving along an heard a pop come from under the truck I pulled over and saw tranny fluid coming out all over the place. I got under it today to see what happened. What i found was that the drive shaft yoke was broken and the drive shaft was hanging free. The transfer case is broken all the way around from the adapter. I don't know yet if the transmission is damaged( I hope not). Any one have this happen to them? I don't do burnouts or horse the truck, just normal everyday driving. Any one know what transfer case I have in this truck. It is a manual on the floor shift. Any help would be great. I really need to get this fixed. One day of driving my old Grand Cherokee and I really miss my diesel. Thanks
2002 chevy 2500hd single cab long bed Amsoil air filter K&N air tube superchips flashpaq programer
Fcaramadre is offline
post #2 of 11 (permalink) Old 03-03-2012, 02:45 PM
Transfercase issue
Did you ever figure out what happened to your transfer case? I think i have developed a slop in mine (2004.5) that is evident when i roll away from a stoplight. Theres a clank and sometimes when i come to a slow stop. Im crazy nervous about it.
gaatvr is offline
post #3 of 11 (permalink) Old 03-03-2012, 03:04 PM Thread Starter
Fcaramadre's Avatar
It was not the transfer case that broke. It was the end of the tranny. I am told that drive line vibration was the cause(a bad ujoint?). The transfercase is fine and a used tranny anf my old transfercase is installed and working ok now. The end of the tranny that broke would have cost $560 from a dealer and the tranny had to come out to replace it. I found a used tranny and transfercase on ebay for $1500.
post #4 of 11 (permalink) Old 03-04-2012, 07:09 PM
Had the same problem with mine, cracked rear housing and also needed a new transfer case. I knew I would need a rebuild eventually because by the time I got to the shop it was bone dry. Tranny made it about a year and finally really needed it done. The cause of mine was also drive line vibration.
hockeyGTP is offline
post #5 of 11 (permalink) Old 03-05-2012, 01:37 PM Thread Starter
Fcaramadre's Avatar
Was it bad ujoints or what that caused the vibration? I had a little vibration before this happened but not much. I was going on vacation for two weeks from work and figured I would change my joints out them. Well it didn't make my vacation and I spent it changing out a tranny and transfer case instead. Now I get a vibration at 50-60 mph when I let off or step on the gas. I am going to change the tranny mount and may look into a new output bearing in the transfer case because it took some real abuse.
post #6 of 11 (permalink) Old 03-05-2012, 03:18 PM
Drive shaft was not balanced, was in an accident, and trashed all the u-joints. They do make a bracket for the rear transmission housing to help so it doesn't crack again.
post #7 of 11 (permalink) Old 03-05-2012, 03:40 PM
primetime_2's Avatar
my 01 had the same clunk and gm will tell you its normal! theres an aftermarket yoke out that you can buy to fix it or u can clean the drive shaft splines and yoke every 15-30k with carb cleaner and moly grease to help but it just don't last! theres a write up in the DIY section thats really good about this!
primetime_2 is offline
post #8 of 11 (permalink) Old 03-05-2012, 03:53 PM
blackdeath's Avatar
blackdeath is offline
post #9 of 11 (permalink) Old 03-05-2012, 04:21 PM
it fits great have on on mine , i installed the brace and pump kit in mine great guys to deal with
05 3500 ccdrw lly, complete lbz banks ram-air intake set-up with with super scoope, egr deleted profab intake elbow , diamond eye 4' duals , diamond eye down pipe and no kitty efi by full throttle customs , edge insight cts for gauges ,lbz mp. and fuildamper .pcv reroute,right and left side boost tubes, banks techi cooler ppe ported fitting , afe rear diff cover magtec trans pan ,does it ever end airdog 2 165 bd manifold, merchant transfercase brace and rub kit , transgo jr, custom convertor . earls 82510aerl for trans cooler ,hellwig bigwig rear sway bar , fleece tap shifter
www.alligatorperformance.com
www.merchant-automotive.com
www.madjacksynthics.com
happyduramax is offline
post #10 of 11 (permalink) Old 03-05-2012, 05:39 PM Thread Starter
Fcaramadre's Avatar
I put the brace on mine when I put it together. I also bought a tranny and drive shaft that was in a truck that had an accident and was totaled out. I wonder if my drive shaft needs to be balanced too? How much does it cost to do something like that?
