| Transmission Shop Discuss the Allison OEM, aftermarket, and the ZF-6. |
| | eBay Motors #21 (permalink) | |
| DuramaxForum Veteran Join Date: Feb 2011 Location: Granbury, Tx.
| Quote:
__________________ 05 lly, bills 5" intake with lbz mouthpiece, ppe manifolds up pipes, 6"rcd custom lift, three inch drop shackles, torsion bolts outs, nitto 420's 305/50/20, ppe tie rod sleeves, airdog II 165 lift pump, egr delete, pcv reroute, 4" turbo back straight pipe, stage 5 tranny from alligator performance ,68 mm turbo from Danville, arp head studs, efilive | |
| Duramax Lifetime Supporter Join Date: Feb 2010 Location: Southern Maine
| Yup, Im thinking so too, now that I just put 2 and 2 together about my truck and my buddies trucks both starting to shift funny at about the same time. Thanks for all the info once again guys! Now all I need to do is cross my fingers and hope nothing got frigged up with my allison. With all the abuse guys put these transmissions through day in adn day out, Im pretty sure a few thousand miles of bad tuning won't kill it, but we'll see. My new tunes should be done tomorrow, or early next week so I'll keep you guys posted as to how I make out.
__________________ 2003 CCSB 4x4 EFI Tuned by ATP -PPE Stage 4 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Ready Lift Leveling Kit -Autometer Boost & Pyro -Airdog II 165 |
| | eBay Motors #23 (permalink) |
| Offical LB7 "Tech" Join Date: Sep 2010 Location: Saint Johnsville, NY
| Yeah, a day or two is max for relearn. It is definately your tuner. I would get my money back!!!
__________________ -Aaron- 2001 GMC Sierra 2500HD, Limited Edition, CC,SB EFI Live V2 w/dsp5 MAX EFFORT by Idaho Rob, EGT's Never higher than 1150* Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler @180,000-New injectors from Lincoln Diesel, CAT Adapter/filter/spacer Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires, MANY More extras inside... ![]() |
| I probably could argue it, but the main thing is that I'm getting Robs tuning. Its my own fault for going with someone like I did, but like we all do sometimes, we try to save a few bucks, and it comes back to bite us in the ass. I should have known better but I tried anyway. Shit happens. The guy that did the tuning is the same guy that gonna load Robs tunes for me so I don't want to burn the bridge ya know? He's a good shit, just has some lousy tunes.
| Well, got some of Robs tunes installed today and all I can say is WOW! What a difference I performance, and shifting. Thanks for the help guys
| No problem! Now you can tell others that Bad tuning will cause your trans to shift like crap!
| | eBay Motors #27 (permalink) |
| Hey guys wanted to get in on this topic. I recently installed an efi live tunned by Idaho Rob. My question is I know that he is a very reputable tuner however when accelerating my truck has VERY erractic shifting. Is this to protect the stock tranny or whats the deal. For $1,100 I would have expected something alot better.
__________________ 03 Chevy 2500 Ext Cab with 78,xxx and counting.6in Suspension Lift with 35x12.50's, EFI Live by "Idaho Rob" w/ DSP5, AirDog II 165, AEM Brute Force, ProFab Air Horn, 4in MBRP Turbo Back Exhaust, and Edge CTS Insight watching it all. |
| | eBay Motors #28 (permalink) | |
| DuramaxForum Enthusiast Join Date: Nov 2010 Location: across the street
| Quote:
might just be something that was overlooked
__________________ CCSB LB7 4x4 | |
| | eBay Motors #29 (permalink) | |
| I'm That Guy... ![]() Join Date: Aug 2010 Location: Gilbert, AZ
| Quote:
First, have you contacted Rob or ATPTrucks.com? Usually they are the fastest source for good answers and information. Second, this is an old thread and you may have been better off creating your own thread as opposed to reviving and old thread that wasn't 100% relevant. To answer your question or attempt to. The Allison transmission is adaptive and has adaptive learning, so it will learn your driving characteristics. If you have driven around for 60k miles like a grandpa on a stock tune and then throw on a 150hp over stock tune and romp on the throttle; you will find that the transmission won't shift right. You can do a re-learn or just drive around on the tunes for awhile as it learns. One other note is that the Allison transmission uses a defuel in between shifts, you may also be feeling that. All of that aside, there could be issues with your truck that are being brought to light such as fuel rail issues. When was the last time you changed your fuel filter? A data log can identify some of the issues, sometimes they aren't as noticeable with stock tuning, but larger tunes bring them to light due to the increased fuel demand. My suggestion is to contact ATPTrucks.com directly, but you can also answer my questions above and maybe we can get you pointed in the right direction. Poor tuning CAN cause shifting issues, but I highly doubt that's the situation here. Have you completed a re-learn? What power level are you driving around at? When do you have erratic shifting? Does this occur when you are getting on the throttle a lot or at all speeds? Can you please elaborate on erratic shifting?
__________________ Tony Non Vendor contact information, URLs and/or links are NOT allowed in signatures or on forum! My opinion is not the opinion of Duramax Forum, Auto Forums, Auto Guide, or other Duramax Forum staff members! CLICK TO READ: FORUM RULES AND DF STAFF! Thank you Rob Coddens (Idaho Rob), Dustin @ ATP, Scott @ SDP, Kory Willis, and Mike L. for all of your help! Shhh... I sold my Dmax and I own a gasser now, don't tell anyone!!! I'll buy another Dmax soon, probably LLY or LBZ. | |
| | eBay Motors #30 (permalink) | |
| Quote:
__________________ 03 Chevy 2500 Ext Cab with 78,xxx and counting.6in Suspension Lift with 35x12.50's, EFI Live by "Idaho Rob" w/ DSP5, AirDog II 165, AEM Brute Force, ProFab Air Horn, 4in MBRP Turbo Back Exhaust, and Edge CTS Insight watching it all. | |
