ZF6 clutch pedal problem - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 07-09-2012, 09:51 PM Thread Starter
o3gerber's Avatar
I have a 04 with the LB7 and the ZF6 manual tranny, i also have a lift with 35's. I just got a +80 and +100 efi live tune for the truck today and everytime that i really lay into it, mash the gas and than go to shift, the pedal sticks closer to the floor. It does not stick all the way to the floor and it still functions correctly put the pedal feels harder to push and is really close to the floor. When this happens i reach down and pull the acuator rod back closer to the clutch pedal and it goes back to normal unless i really mash the gas and shift. The truck also has 120,000 and it is the stock clutch, and my flud level is good for the master cylender. it has never happened untill i got this tune.
2004 Silverado 2500HD RCLB LB7 With ZF-6
EFI Live by Duramaxtuner, DSP5 Switch
Banks Ram-Air Intake, 5'' Straight Pipe
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Glow Shift Boost + EGT Guages
Zone 6in Lift
315/75R16 Baha Claw TTCs
o3gerber is offline
post #2 of 5 (permalink) Old 07-11-2012, 03:28 PM
Chavez91's Avatar
From my understanding, the stock clutch is doing good to be holding the stock power, but your throwing a 80hp and 100hp tune at it. I wanna bet that it has something to do with the clutch slipping and getting hot. Especially being that it only started doing it when you got the tunes and only happens when you get into it. Clutch assembly cools off and everything works fine again. Thats my guess. So your probably gonna need to upgrade from that stock clutch and dual-mass flywheel. Southbend Clutches are the most talked about. Valair is another brand.
Feel free to correct me if I'm wrong.
Sent while driving.....
Josh
'04 LLY "Farm Truck"
*LML Hybrid w/ Built Trans *
500K Milles
'05 LLY
*Built Trans and a Tune*
OPDT
When in doubt, scrap EFILive and do it yourself
Chavez91 is offline
post #3 of 5 (permalink) Old 07-11-2012, 04:34 PM
Milk_Man's Avatar
mine does the same thing on stock tune. doesnt slip at all, but after a hard gear pull or 3 it likes to stay down. i was thinking maybe flush the fluid and replace, rebleed and see what happens. my camaro did the same thing and it was a common problem. had to drill out the openings in the stainless hose going from the MC to the SC.
2001 Regular Cab 2WD ZF-6
Tbar crank
265's
5" Straight Pipe
Edge CTS
ADII
Efi Live by Idaho Rob
Southbend ceramic DD
Nicktane CAT filter
More to come... Meth, Trac Bars
Milk_Man is offline
post #4 of 5 (permalink) Old 07-11-2012, 04:47 PM Thread Starter
o3gerber's Avatar
I am in the process of saving up for a clutch because both tunes slip it now so it could be like you said about heating up. I am gonna take it easy on her till i get a new clutch, a new pedal assembly and see where i am at. Thanks for the input guys
Sent from my C771 using AutoGuide.Com Free App
South Bend DD
Air Dog 165
PPE Boost Valve
Pro Fab Intake Horn
Zone 6in Lift
o3gerber is offline
post #5 of 5 (permalink) Old 07-11-2012, 06:51 PM
twin64's Avatar
I don't think you need a new pedal assembly but definitely replace the slave cylinder while you are in there. You won't regret doing a dual disc either!
Sold: 2002 2500HD ECSB ZF-6, SB DD, EFI with a DSP-2 switch, Profab downpipe, 5" exhaust, Airdog II 165, AFE intake, 3 inch drop shackles, home made traction bars.
twin64 is offline
