My experience with Big Dipper - Page 3 - Chevy and GMC Duramax Diesel Forum
Old 11-15-2012, 04:11 PM   eBay Motors  #21 (permalink)
poberly's Avatar
I've got a Suncoast 1058. It locks up firm but that doesnt bother me
05 LLY cclb- full s&b intake, 4" exhaust, tie rod sleeves, cognito braces, EGR block, PPE fuel valve, fass lift pump, EFI live tuned by Danville Performance, pump rub fix, MA trans brace, Big Dipper stage IV trans
poberly is offline   Reply With Quote
Old 11-15-2012, 04:16 PM   eBay Motors  #22 (permalink)
rd05lly's Avatar
Good deal
05 CCSB EFI Live by Kory Willis
76 Dodge Charger SE
http://www.duramaxforum.com/forum/91...mber-list.html
www.TrollPerformance.com
rd05lly is offline   Reply With Quote
Old 11-15-2012, 04:29 PM   eBay Motors  #23 (permalink)
If you dont mind me asking, About how much did the tranny build cost ya?
07.5 lmm cc/sb 20 xd monsters 305 terra grapplers cognito uca's 15% tint all around, EFI live by rob 5 inch straight pipe, egr block off, Trans go jr, Pvc reroute, Air Dog, Tie rod sleaves, Piller guages
kawikid is offline   Reply With Quote
Old 11-15-2012, 04:38 PM   eBay Motors  #24 (permalink)
The guy that built my Big Dipper trans lives in Peoria, IL... He used to do trans work for Merchant.. Let me know if you want his info.. Does it the same way George would just a little closer if you are in the Midwest
Zac
2003 LB7 White EC/SB
EFI by Rob w/DSP 5 / Danville stage 2 68mm turbo/ BigDipper trans with ML converter(built by Todd=Stroke 250) / Raptor 150 / Big Dipper 45% over injectors / Wicked Stage 3 Stroker pump / 4in MBRP dp back to a 6" black Mitre cut stack / 8000K HID Hi/Low / Recon smoked LED tails, cabs, and 3rd brake / Rancho 9000's / DHD Steering brace
Originally Posted by blacksmokelb7 View Post
Rather see mama in a whore house then a brother in a dodge
zacwht20 is offline   Reply With Quote
Old 11-15-2012, 06:42 PM   eBay Motors  #25 (permalink)
rd05lly's Avatar
Todd will be getting a call when I am ready. You can PM his number thanks.
76 Dodge Charger SE
Old 11-15-2012, 06:48 PM   eBay Motors  #26 (permalink)
wvtork's Avatar
George is a true professional and the best at what he does,I thrash mine daily and the crisp shifts and solid pull always make me smile deff worth the drive or shipping cost.
07 ecsb lbz lt3 edge 5'' to 7"black mitres ,stage 4 big dipper with 1058 sc, 4094 avnt, 45 over nozzles and atp ecm and dsp5 ,tb keys 325 cooper disc stts on 18 inch 197 EAGLES air dog II 165 ppe rail fitting and fprv shims and bushwhacker pockets http://dmaxstore.com/http://www.getsomeperformance.com/
wvtork is offline   Reply With Quote
Old 11-25-2012, 11:41 AM   eBay Motors  #27 (permalink)
poberly's Avatar
I don't mind at all, but I, like every other person with a Big Dipper trans, won't disclose the price. His prices vary because he builds for your application. When he calls you, he asks questions about your plans and goals with the truck. But I will say that he was lower than any other trans builder I got a quote from. If you want his number, pm me and I will be more than happy to give it to you.
Old 11-25-2012, 11:47 AM   eBay Motors  #28 (permalink)
battlegraduate09's Avatar
I agree ^
This alone should tell you somethin. The way you George treats you makes you want to respect him enough not to go around posting prices or speaking for him. To me, I'd much rather have to call myself and speak with a builder of George's caliber than joe blow who charges a set price no matter what the build plan is. It should give you that much more confidence in him building your trans. Not only do you get an awesome trans but you'r hard pressed to find better customer service and satisfaction.
Josh
04 LLY CCSB 4X4
battlegraduate09 is offline   Reply With Quote
Old 11-25-2012, 03:29 PM   eBay Motors  #29 (permalink)
DMaxxrus's Avatar
If someone could pm me his number that would be great. Im sure hes busy so if you know the best time to give him a call or whatever that would be appreciated also.
DMaxxrus is offline   Reply With Quote
Old 11-25-2012, 07:52 PM   eBay Motors  #30 (permalink)
poberly's Avatar
Dmaxxrus I sent you his number. Text him and he will call.your right he is busy and he won't answer a call.
