| Transmission Shop Discuss the Allison OEM, aftermarket, and the ZF-6. |
| Junior Member | Transmission won't go in gear after Trans Go Jr Install Just finished up last night on the install of a Trans Go Jr. install following instructions I found on here. Filled with fluid and went to start. I tried to put in gear after starting and it won't come out of park! I also had the batteries disconnected for three days. The truck is an 08 LMM. Any ideas would be appreciated before I pull the pan back off and drain the golden Transynd out Thanks
__________________ 2008 Chevy DMAX 4x4 Crew Idaho Rob EFI Live AutoCal, AFE 7 drop in, PPE stock air box mod, 5 inch Flo Pro, Edge CTS Insight, Transgo Jr., ATP resonator plug, Pcv reroute and EGR block 295/70/17 Nitto Terra Grappler/17x9 Gear Alloy with +10 b.s. Ebay Pyle backup cam |
| | eBay Motors #2 (permalink) | |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| Quote:
I would say you didnt get the manual valve pin engaged into the inside detent lever slot correctly. Also be sure that the valve body is torqued precisely to 9ft lb or you can risk warping it and having the other valves lock up in there bores causing more headaches....or simply the shift cable got smashed and is binding up.
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods | |
| You have missed the shift pin in the shift valve--or the wrong place-- Most common problem-- if it does not go into gear.
__________________ Chevy 04.5 LLY, 2X, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PCV, 65 Gallon replacement Aero tank, PPE on 2, LBZ-mp, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets. Last edited by jc1843; 11-08-2012 at 06:42 PM. |
| like a Ninja ![]() ![]() Join Date: Jan 2009 Location: Coeur d'Alene, Idaho
| does the gear selector light up or no?
__________________ Holton-22 USMC "06 chevy 2500HD LBZ 6spd,black and blacked out, CCSB 4X4 Custom Twins, EFI by IdahoROB , 40% nozzles, PPE manifolds & Up-pipes, BD Intercooler, lowered on 20" Fuels, 6000K HIDs, BIG Thanks to: IdahoRob, Mike L., Suncoast, BD Diesel, PPE, Fuel, S&B, Industrial Injection ![]() Alligator Diesel Performance - 208-777-1977 |
| Junior Member | Shift lever doesn't move, gear indicator lights up, and as long as I use a hospital clean drain would you guys recommend reusing fluid?
| Senior Member Join Date: Jan 2012 Location: Derby, Ks
| I did the exact same thing. My shifter wouldn't move. Took the pan back off and I didn't get the shift pin back in the valve body correct. Simple fix. Good luck.
__________________ 2008 RC/LB EFI Live, 5" flo-pro w/muff, DE downpipe, EGR blocked, PCV re-routed, trans-go jr, Insight CTS w/EGT probe 28K miles Chris |
| ^^^^there seems to be your answer
| Pshh give him the credit..i see how it is
| Junior Member | I missed the shift pin what a dummy I am but man is this thing smooth,almost too smooth! Pic attached of my first attempt! Doh!!!ImageUploadedByAG Free1352773202.906006.jpgeq Sent from my iPhone using Autoguide.com Free App
