DRP High Performance Transmission Cooler Repair Lines - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 07:08 AM   eBay Motors  #1 (permalink)
DHarrienger's Avatar
Has anyone used this kit? If so how do they hold up i need to fix my lines and id like to only have to do it once..
2006 LBZ Crew cab , 4 "MBPR straight pipe, EFI Live dsp5, ProFab EBR delete pipe with LB7 up pipe , PVC Reroute, Transgo Jr Shift kit., Cooper Discovery ATP 265-75-R16, Rare Parts Tie Rods
DHarrienger is offline   Reply With Quote
Old 11-20-2012, 08:57 AM   eBay Motors  #2 (permalink)
anybody?
Old 11-23-2012, 02:52 AM   eBay Motors  #3 (permalink)
soo no body has used these at all?.......
Old 11-23-2012, 04:54 AM   eBay Motors  #4 (permalink)
I have no experience with DRP lines but I did install lines from reds auto rehab. You can find them at Reds Auto Rehab, solutions for common automotive problems. . When I did my installation Red's offered the best price. I have not had any problems with them and they were a quality product. I installed the 5/8" lines but if I recall when I was researching others have installed 1/2" lines with out any issues.
When I did my installation I could not get the lines to install the exact same location as the factory and majority of this issue was due to the increased size. Just as a safety measure where the lines might contact something hot or contact something and cause abrasion I purchased a slightly larger diameter hose and cut small sections, split the hose and zip tied in on the line in these areas. I probably did not need to do this but it provided peace of mind and I don't have to worry about being stranded in Colorado Mountains Elk Huntin.
speak2mlv is offline   Reply With Quote
