Spin on change - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 12-01-2012, 09:52 AM Thread Starter
DuramaxSilvy's Avatar
Spin on change
Truck is in sig. When I change my spin on, what fluid do I prefill it with? Any ol' dex vi? Or is there a certain kind? Or do i not have to prefill? I'm not interested in ordering oem fluid and oem filter. Delco is fine from carquest
2005 4x4 2500HD LLY ECSB
Arp studs, Grade C's, 3" DP, Whats an EGR?, Fuel Filter 3/8 Spacer, ATP Autocal DSP2 80hp street/40hp tow vvt brake, 4" MBRP Turbo Back, 5" Tip ,AFE Mouthpiece, All On/Dual Park Lights, Leveled Kool-Vue Tow Mirrors, 18%Tint, debadged, Discoverer AT3's, 2006 Lower Valance, Extang Trifecta, Amsoil where ever oil should be
DuramaxSilvy is offline
post #2 of 8 (permalink) Old 12-01-2012, 10:13 AM
Banned
You don't need to pre fill it. If you do, it would be best to do a double drain and fill with castrol transynd.
dieselnuts6 is offline
post #3 of 8 (permalink) Old 12-01-2012, 10:42 AM
bubblebutt's Avatar
spin it on and remember to transfer over magnet , just top off with a bit of dex 6,
2008 GMC Dually LMM
6" lift 285/75R17 "E" TOYO M/T
Banks intake/DPFdelete with MBRP exhaust
PPE Hot Race tuner / TransGo Jr. / Pillar gauges
JVC - DVD/Nav system & Back up camera/2500w inverter/ 55w reverse lamps/Amber strobe lights X4 corners
front hidden hitch/rear hitch/turn over ball 5th wheel hitch/custom grille
DRW # 101
bubblebutt is offline
post #4 of 8 (permalink) Old 12-01-2012, 10:44 AM
LHN...We ARE the Joneses
Originally Posted by DuramaxSilvy View Post
....Any ol' dex vi?....
I prefer to pre-fill the filter….simplicity.
With your LLY 5-spd, you'll need the Dex-III equivalent, not Dex-VI. Your Delco local source is fine.
But for future filter needs, sourcing from the DF Vendors Here will get you the Allison filter for 1/3-1/2 the price of retail.
Add in Racor fuel filters to the purchase and $ave even more, while having the best filtration available for both in stock form.
Best+Cheap=Win
Hook'em_Horns! is offline
post #5 of 8 (permalink) Old 12-01-2012, 10:47 AM
mike diesel's Avatar
I always prefill the filter. And you need dex 3 not dex 6
05 Dmax/Allison
10.86@133
mike diesel is offline
post #6 of 8 (permalink) Old 12-01-2012, 12:25 PM Thread Starter
thanks guys!
post #7 of 8 (permalink) Old 12-03-2012, 06:37 PM
KB3MMX's Avatar
Fyi, Dex fluid is pure dog crap...
Allison Transynd is going to do much better if you plan on keeping it.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #8 of 8 (permalink) Old 12-05-2012, 05:27 AM
X2
Unless you have a built tranny then I would just switch over to Transynd and call it good.
MTL_Dmax is offline
