Allison rebuild questions - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 01-16-2013, 11:54 AM   eBay Motors  #11 (permalink)
SnafuPossum's Avatar
Originally Posted by jc1843 View Post
Todds is highly recommended-- many have had work done there. Mike L even recommended Todd in another thread in the Transmission section.
Here is the link-! New built trans
Then why would they tell him such b.s. first thing you learn about our trucks when visiting any forum its the total opposite of what they told him.
~Ross~23~
2004 LB7 2500HD ccsb: 5in exhaust, cognito upper control arms, rare parts tie rods, cai, appradio2
www.trollperformance.com
SnafuPossum is offline   Reply With Quote
Old 01-16-2013, 11:59 AM   eBay Motors  #12 (permalink)
6.6 Duramax's Avatar
Yeah, Todd is who I would want to build mine since Mike L. is a long distance from me. Its nice to know that there are some good builders close to me.
2006 GMC Sierra 4x4 LBZ ccsb
EFI Live DSP5 (Spade) tuned by DuramaxTuner.com
Magnaflow 5'' DP back ss exhaust from http://dmaxstore.com
Re-route and Resonator plugged
5/8'' Trans lines
SS Billet Grilles
1995 Dodge Ram 2500 12 valve Cummins
Cold air intake
4'' MBRP exhaust
New trans
6.6 Duramax is offline   Reply With Quote
Old 01-16-2013, 01:25 PM   eBay Motors  #13 (permalink)
rms
rms's Avatar
There's a disconnect here - it looks like you should talk to Todd personally.
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/75/16 Cooper ATP's - 8' Bedslide
Amp Steps - Bilsteins - Fumoto
rms is offline   Reply With Quote
Old 01-16-2013, 01:46 PM   eBay Motors  #14 (permalink)
Longbeds FTW
DMAXchris's Avatar
That's not the same Todd, Jerry. The guy Mike was referring to is in Illinois!!! I have no clue who this guy is in BERKS COUNTY, PENNSYLVANIA!!!
06 Dmax/Allison EC/LB 4x4
TTS PowerLoader III • full billet Bully Dog stage 7 • BCI 7" intake with custom snorkle • fender vents • quintuplet shotgun cat stacks • 22" Rockstars • Huge "Dirtymax" sticker • -60% nozzles • extra pcv with dual catch cans • compounded EGR • silencer ring MIA • 4.56 gears • Lowered 5.5" in the back • Lifted 6" in the front • Monster sticker • flat bill mod • 8' CB whip • blacked out reverse lights • gauges everywhere
08 BMW 528xi
00 Buick Regal GS
DMAXchris is offline   Reply With Quote
Old 01-16-2013, 02:00 PM   eBay Motors  #15 (permalink)
Oops, yeah never heard of this Todd's shop the op is using. Todd Spalding is a different guy form IL.
5/8'' Trans lines
SS Billet Grilles
Cold air intake
4'' MBRP exhaust
New trans
Old 01-16-2013, 02:43 PM   eBay Motors  #16 (permalink)
rms
rms's Avatar
^^^ And, there it is . . .
Old 01-17-2013, 07:06 AM   eBay Motors  #17 (permalink)
Super Moderator
jc1843's Avatar
OK, sorry for the bad information. My Mistake-!
Old 01-17-2013, 02:32 PM   eBay Motors  #18 (permalink)
Talked the shop and they're doing stronger alto clutches, transgo shift kit, and a billet triple disk convertor. I feel better now that they told me this and the transmission should hold the mods I have just fine.
Current Truck: 2003 GMC Sierra 2500HD Regular Cab LB7 4x4, Farm Truck, Built Auto, Industrial Injection Race 1's Injectors, Air Dog 165 Lift Pump, EFI Live, Edge CTS, Gets the Job Done Now
Previous Truck: 1995 Dodge Ram 2500 Regular Cab 12 Valve 4x4, Farm Truck, 5 Speed South Bend 550HP Single Disk, BD Street Series Injection Pump 4000RPM Governor Springs Modified Fuel Plate, 5" Flo-Pro Exhaust, Fancy Green Paint Job, Got the Job Done
RegularCabLB7 is offline   Reply With Quote
Old 01-17-2013, 08:05 PM   eBay Motors  #19 (permalink)
Mike L.'s Avatar
Good luck. I myself would have gotten out of dodge quick. I don't trust these guys.
2011 LML Chevy Duramax CCSB 4X4
Custom Transmissions, Converters, Kits. Coolers.
Suncoast converters, Goerend custom converters.
714 870 7300
Mike L. is offline   Reply With Quote
Old 01-21-2013, 09:46 AM   eBay Motors  #20 (permalink)
KB3MMX's Avatar
Run away !!
Run Forrest RUN !!!!!!!!!
After the BS they pumped you with before, you need to get your truck out of there ASAP !!
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
