Allison rebuild questions - Chevy and GMC Duramax Diesel Forum
Old 01-15-2013, 02:41 PM   eBay Motors  #1 (permalink)
I'm having my transmission rebuild by a local trans shop (Berks County, PA) called Todd's Transmission. They're doing a kit good for 700 HP and 1100 FT LBS, that will be more then enough for me don't really plan on adding much more power than I have currently. The main question/concern I have is when I asked what convertor they where going to use the trans shop said they where just gonna send my stock one out and have it rebuilt because the stock convertor's our very strong and will be able to handle the power. The shop also said that my computer for the trans was probably bad causing my shifting problems (wouldn't shift out of 3rd gear) saying the Allisons our strong trans and didn't think a chip/programmer could ruin one but then after going through the process of doing two trans relearns deciding it was actually the C4 clutch packs. The shop is specialized and certified in rebuilding the Allison trans and they're "experts" I just think that the stock convertor won't hold up and was wondering your opinions on here. Thanks for the help.
Current Truck: 2003 GMC Sierra 2500HD Regular Cab LB7 4x4, Farm Truck, Built Auto, Industrial Injection Race 1's Injectors, Air Dog 165 Lift Pump, EFI Live, Edge CTS, Gets the Job Done Now
Previous Truck: 1995 Dodge Ram 2500 Regular Cab 12 Valve 4x4, Farm Truck, 5 Speed South Bend 550HP Single Disk, BD Street Series Injection Pump 4000RPM Governor Springs Modified Fuel Plate, 5" Flo-Pro Exhaust, Fancy Green Paint Job, Got the Job Done
RegularCabLB7 is offline   Reply With Quote
Old 01-15-2013, 02:42 PM   eBay Motors  #2 (permalink)
like a Ninja
guytonLBZ's Avatar
if they said that id go get that truck and find someone else....
Holton-22 USMC
SOLD "06 chevy 2500HD LBZ 6spd,black and blacked out, CCSB 4X4
Custom Twins, EFI by IdahoROB, built trans W/1058 by ME, 40% nozzles, PPE manifolds & Up-pipes, BD Intercooler, lowered on 20" Fuels, 6000K HIDs,
BIG Thanks to: IdahoRob, Mike L., Suncoast, BD Diesel, PPE, Fuel, S&B, Industrial Injection
Alligator Diesel Performance - 208-777-1977
guytonLBZ is offline   Reply With Quote
Old 01-15-2013, 02:42 PM   eBay Motors  #3 (permalink)
mike diesel's Avatar
Sounds like you need to take it to a different shop.
05 lly
EFI Live
Built Trans
BT Lockup Box
GDS Billet 72vgt
Supporting Mods
mike diesel is offline   Reply With Quote
Old 01-15-2013, 02:47 PM   eBay Motors  #4 (permalink)
Varty Yo's Avatar
stop, no, dont!
2006 LBZ
Mike L Stage Awesome!
Airdog2 165, 5" MBRP Turbo back
EFI Live tuned by Idaho Rob, DSP5, ATP
Cognito set at 8" Nor-cal Truck
SS idler support/ Rare parts tie rods
37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes
HID's All on mod/ AMP reaserch steps
Varty Yo is online now   Reply With Quote
Old 01-15-2013, 04:36 PM   eBay Motors  #5 (permalink)
Thanks for the fast replies, I'll be giving the shop a call tomorrow morning. I just wanna be back on the road again and can't wait for the bigger trans.
Old 01-16-2013, 07:19 AM   eBay Motors  #6 (permalink)
like a Ninja
guytonLBZ's Avatar
if you let them just replace the C4 cluth pack and put a factory TC back in it its all a matter of time before youre back at square root 1 again.
Holton-22 USMC
Old 01-16-2013, 07:21 AM   eBay Motors  #7 (permalink)
Longbeds FTW
DMAXchris's Avatar
Run away FAST!
REBUILDING AN ALLISON & BUILDING AN ALLISON FOR HIGH PERFORMANCE ARE TWO COMPLETELY DIFFERENT THINGS!
06 LBZ EC/LB 4x4
Built Motor/Trans • Bullseye s375 • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115
There are a lot of hacks in this industry. Be very careful with who you choose to do work on your truck!
DMAXchris is offline   Reply With Quote
Old 01-16-2013, 07:25 AM   eBay Motors  #8 (permalink)
blitzin247's Avatar
RUN NOW!! They have NO CLUE what they are talking about. If you let them
Build it you WILL regret it, do it right the first time, don't trust them.
Purchased 11/15/12: 2004 LB7 CCSB, ATS 4000 turbo, upgraded injectors, Diamond Eye 4 inch turbo back exhaust, H2's on 315/70/17's, Ranch hand front bumper. EFI LIVE by Kory Willis
Purchased parts awaiting install:
Moog problem solver lower ball joints, Moog pitman and idler arm, AD 165
Special thanks to: Brent@LDS, mrmanners@Synthetic Motorsports, and [COLOR="Magenta"]Kory Willis
Jesus loves YOU, Have you asked Him to be your Savior yet?
blitzin247 is offline   Reply With Quote
Old 01-16-2013, 07:38 AM   eBay Motors  #9 (permalink)
6.6 Duramax's Avatar
I made the same mistake with my dodge's tranny. Now I have a stock tranny for the price of a built one. Wish I would have done more research on the shop I went to and did it right the first time. Is there even anyway to get out of that shop if they have already started on it? I wish you the best of luck man.
2006 GMC Sierra 4x4 LBZ ccsb
EFI Live DSP5 (Spade) tuned by DuramaxTuner.com
Magnaflow 5'' DP back ss exhaust from http://dmaxstore.com
Re-route and Resonator plugged
5/8'' Trans lines
SS Billet Grilles
1995 Dodge Ram 2500 12 valve Cummins
Cold air intake
4'' MBRP exhaust
New trans
6.6 Duramax is offline   Reply With Quote
Old 01-16-2013, 11:16 AM   eBay Motors  #10 (permalink)
Super Moderator
jc1843's Avatar
Todds is highly recommended-- many have had work done there. Mike L even recommended Todd in another thread in the Transmission section.
Here is the link-! New built trans
