Oil for Allison - Chevy and GMC Duramax Diesel Forum
Old 01-21-2013, 07:09 AM   eBay Motors  #1 (permalink)
Oil for Allison
I have a 06 Duramax, 130,000 miles and trying to get better fuel mileage. Going to do a tune, fix EGR, change converter on exhaust and add trans kit. I use amsoil in trans now and the guy doing the work would like to use super shift by amsoil and on amsoil website looks like ATL fluid would be better for my application. Not going race it or pull on a track just towing a 5000# trailer to jobsites. It was suggested to put on a 4" exhauts put not sure I would get a return of $600 on fuel savings and it would also be louder. Anybody have thoughts on oil and 4" exhaust?
Randy 06 is offline   Reply With Quote
Old 01-21-2013, 07:13 AM   eBay Motors  #2 (permalink)
Salt sucks
WVRigRat05's Avatar
Dex 6. Alot of guys run amsoil or transynd. Why 600? YOu can get a MBRP aluminized 4" exhaust for just under 300 bucks and your truck will run alot cooler.
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Motor died 1/19/12 190.131 mi.
Trans. died 7/27/12 200,136 mi.
Built motor/Trans and tuned by Blackout Performance
some parts to take it.
2011 30' Puma KDBSS
WVRigRat05 is online now   Reply With Quote
Old 01-21-2013, 07:49 AM   eBay Motors  #3 (permalink)
600 for 4" SS. Does 4" do much for fuel mileage?
Old 01-21-2013, 07:57 AM   eBay Motors  #4 (permalink)
Cayenne's Avatar
everyone on here recommended i run transynd when i change.
Proud Member of "the pup bros"
2012 Chevy Silverado 2500 HD LT, CC/SB, 4x4, 6.6L Dmax LML w/Allison. BONE STOCK. With Edge Insight monitor. Remote start. 80 gallon ATTA tank. B&W turnover ball. Cattleman HD front bumper replacement. 15% tint. Amsoil oil and filter. TranSynd. S&B Dry CAI. Firestone Ride Rite air bags with Air Lift in cab compressor, gauge, and controls.
Originally Posted by jwcgmc1985 View Post
POWER STEERING is that a powertrain item?
i just want more than tow master
i want to be......Post Master
My LML Build Thread LML Oil Usage Thread
My Hauls Thread
Cayenne is offline   Reply With Quote
Old 01-21-2013, 09:34 AM   eBay Motors  #5 (permalink)
KB3MMX's Avatar
Randy, Transynd or Amsoil "Torque Drive" is the best choice for your Allison transmission's long term health and will reduce required maintenance.
Using Amsoil "Super Shift" is only recommended for a race trans or to salvage a slipping one. "Super Shift" doesn't have the friction modifiers of regular ATF thus causing clutches to grab MUCH harder.
The 4" exhaust will help some with fuel mileage but it's not going to be huge. Your EGTs will drop from the exhaust due to better flow, which is a good thing.
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
Old 01-21-2013, 03:22 PM   eBay Motors  #6 (permalink)
I use Torque Drive now but I see amsoil came out with ATL that replaces DexronVI. Was not sure if this was better for my truck.
Do you think the 4" exhaust would be worth putting on? They say it will be a little louder but I'm not sure how much. Don't want to hurt the resale and I put on about 30000 miles a year.
Old 01-21-2013, 03:29 PM   eBay Motors  #7 (permalink)
I'm That Guy...
TDFDiesel's Avatar
Allison TranSynd or Dex 3. I wouldn't run Dex 6 in anything.
Tony
Non Vendor contact information, URLs and/or links are NOT allowed in signatures or on forum!
TDFDiesel is offline   Reply With Quote
Old 01-21-2013, 03:32 PM   eBay Motors  #8 (permalink)
KB3MMX's Avatar
Randy, The ATL(low vis) is fine and shifts slightly faster but the Torque Drive will protect a little better.
I have stainless 4" W/ Muffler, it's more of a daily driver friendly, non-teenager type setup.
My Antenna-SteppIR
Old 01-21-2013, 04:04 PM   eBay Motors  #9 (permalink)
Thanks for the info. I was wondering if the ATL would be a low vis for what I do. I'll stick with T-Drive
All the kids around here have 4 or 5" straight pipes. Little to loud for me pulling a trailer every day
Thanks Again
Old 01-21-2013, 04:15 PM   eBay Motors  #10 (permalink)
KB3MMX's Avatar
No problem.
Yes, most kids around here run straight pipes too, I didn't want that racket either so I went with a muffled setup.
My Antenna-SteppIR
