"Shift Range Inhibited" and wont shift into 4th - Chevy and GMC Duramax Diesel Forum
Old 02-24-2013, 03:27 PM   eBay Motors  #1 (permalink)
james007's Avatar
Hey guys my lb7 suddenly started getting a warning message on the dash saying shift range inhibited when i go to put it in gear. and when i finally get it to go into gear, i cant go past 60km/h because it wont shift into 4th gear. i cleaned the switchs on the side of the tranny with break clean then put synthetic grease in them, and its still doing it. I know theres someone i have to replace i just dont know waht. thanks.
2003 GMC LB7 "Daisy"
Full K&N Intake
DSP5 EFI LIVE Switch BD Watch Dog
PPE Boost Vavle BD High Idle Kit
MBRP 4" Sraight to 6" angled stack
Needs: some body work and injectors soon!
james007 is offline   Reply With Quote
Old 02-24-2013, 03:40 PM   eBay Motors  #2 (permalink)
boostnlb7's Avatar
Its a little black box on yur tranny i think its called the shift control modulator. Im not sure if thats what it is but ive had to replace mine once when it said the same thing. Mine also does that when i limp it
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 02-24-2013, 03:51 PM   eBay Motors  #3 (permalink)
james007's Avatar
does it when you limp it? what does that mean
Full K&N Intake
Old 02-25-2013, 03:49 PM   eBay Motors  #4 (permalink)
james007's Avatar
SOMEONE PLEASE HELP LOL, can i change this part by my self??? is it worth doing it on my back in the yard??
Full K&N Intake
Old 02-25-2013, 04:06 PM   eBay Motors  #5 (permalink)
james007's Avatar
I cleaned the plugs and the shift range inhibited seemed to stop but its still not shifting past 2000 RPM
Full K&N Intake
Old 02-25-2013, 05:04 PM   eBay Motors  #6 (permalink)
Diesel Place : Chevrolet and GMC Diesel Truck Forums
Check this out ^^. ~$60 part at most Allison dealers.
Sounds like this will cure the issue.
2k4.5 GMC D/A...
outlawed_LLY is offline   Reply With Quote
Old 02-26-2013, 03:59 PM   eBay Motors  #7 (permalink)
james007's Avatar
THANK YOU!!!!
Full K&N Intake
