Old 02-12-2009, 03:07 PM   eBay Motors   #11 (permalink)
AU Alum
AU Alum's Avatar
Originally Posted by High Voltage View Post
Torque Drive is not compatible with DERON VI
Where did you get this information? I've looked all over Amsoil's site and can find nothing stating that Torque Drive is not compatible with Dexron VI. All that I can find is that Amsoil states that all of their fluids are compatible. I'm not saying that you're wrong, but I would love to see where you are getting your information. I'm always willing to learn somehting new.
White 2007.5 2500HD LT Quad Cab SB, LMM, Automatic, 4x4
Modifications by NOR CAL TRUCK: Cognito 4" Suspension Lift, Cognito Heavy Duty Tie Rods, Bilsteins all the way around, Sulastic Rubber Springs, 52 Gallon Titan Tank, Black XD Revolvers 18x9, 325/60/18 Nitto Terra Grapplers, Autometer Pillar with Phantom Boost and Pyro, Transgo Jr. with Mag Htyec deep pan, EGR Block Plate, BD Exhaust Manifold, Air Lift Air Bags with WirelessAIR, and Nicktane Filter Kit
EFI Live tuned by Idaho Rob
Other Mods: 4" MBRP Exhaust
AU Alum is offline   Reply With Quote
Old 02-12-2009, 03:13 PM   eBay Motors   #12 (permalink)
High Voltage
High Voltage's Avatar
You can not use Torque drive in a Dexron VI application is what I was saying.
2008 GMC Sierra Ex Cab 2500HD 6.6L LMM Z71
Edge juice W/ Attitude
Skyjacker front level kit
Boss Power VXT Plow
Lubed by AMSOIL
High Voltage is offline   Reply With Quote
Old 02-12-2009, 03:18 PM   eBay Motors   #13 (permalink)
lastcall190
Now I'm royally confused... I post something in the morning and don't check till evening and this is what happens I guess
Taken from Amsoil's website:
Product Applications
AMSOIL Torque-Drive™ is recommended as a direct replacement for TranSynd® Synthetic ATF in heavy duty, on and off highway automatic transmissions manufactured by Allison,® General Motors,® Ford,® Voith® and ZF® or wherever the standards TES-295, TES-389, C-4, Dexron® III, Mercon,® Voith G-1363 or ZF® TE-ML 14C are specified. Examples of operations that benefit from using AMSOIL Torque-Drive™ include municipal or transit buses, motor coaches, garbage haulers, motor homes, delivery vans, emergency vehicles, school buses, dump trucks, utility vehicles, cement trucks, line haul trucks and tow trucks.
Where extended drain intervals are not specified by the original equipment manufacturer (OEM), it is recommended that AMSOIL Torque-Drive™ be evaluated with oil analysis at standard OEM drain intervals or more frequently to establish proper drain interval. Where extended drain intervals are recommended by the OEM, follow that recommendation. This includes the recommendations set by Allison® in document #1099F for TES-295 fluids.
So my 2006 LLY is a Dex...3 then? I will look in the manual later but I'm at work right now and can't remember off hand.
-J
2006 LLY EC/SB
MBRP 4" Turbo Back
PCV Reroute
EGR Blocked
lastcall190 is offline   Reply With Quote
Old 02-12-2009, 03:37 PM   eBay Motors   #14 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
Torque Drive Is Recommended for any and every Allison Application. It was actually specifically designed for the Allison transmission long before the Allison went into these trucks.
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Recommended for use in applications specifying Allison® TES-295 or C4, DEXRON® III, MERCON®, Voith G-1363, ZF® TE-ML 14C
As for Compatibility, Torque Drive is not interchangeable with other fluids, but the other Universal ATF is...
I was wrong... I checked it out and it IS interchangeable with any other fluid...
Let me know if I can help you with that...
God Bless
Chris
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
Old 02-12-2009, 04:36 PM   eBay Motors   #15 (permalink)
AU Alum
AU Alum's Avatar
Now I'm confused.
Is it OK to add Torque Drive to an Allison Transmission that previously had Dexron VI in it without doing a complete flush first? Will there be any problems with the Torque Drive and the small amount of Dexron VI left in the transmission mixing?
I was under the impression that this would be fine, but I hope you can clear this up for me, Chris.
Old 02-12-2009, 04:49 PM   eBay Motors   #16 (permalink)
bigdaddydiesel
Yes, Torque Drive IS interchangeable. I had to check to make sure because it did not sound right to me, but I have verified for a fact that Amsoil Torque Drive IS completely Compatible with every other fluid recommended by Allison for the Allison. So to answer your question, yes,, you can get away with only doing the change with the Spin on filter and Torque Drive and you will be fine.
Chris Kelley
Email
1-888-563-5143
Old 02-12-2009, 04:55 PM   eBay Motors   #17 (permalink)
AU Alum
AU Alum's Avatar
Thanks. That's what I thought I was reading, but I wanted to make sure after some of the posts I've seen. I appreciate your help.
Old 02-12-2009, 04:58 PM   eBay Motors   #18 (permalink)
bigdaddydiesel
No problem at all, yeah, I had to go back and check for myself, I have Amsoil on the brain but I have been fielding so many question in this past week that they are beginning to run together...
Let me know if I can be of any further help to you...
God Bless
Chris
Chris Kelley
Email
1-888-563-5143
Old 02-12-2009, 06:22 PM   eBay Motors   #19 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
so is there any benefit to running dexron VI or III?
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is offline   Reply With Quote
Old 02-12-2009, 06:40 PM   eBay Motors   #20 (permalink)
bigdaddydiesel
Thumbs up Torque Drive vs Universal ATF????
This is just to answer this question.
The Universal ATF is for those owners who feel the need to increase their drain intervals to more than those called for by Allison.
Torque-Drive™ was specifically engineered as relief for the those dealing with the high cost of TranSynd®
Click Here for Lab Comparison of Torque-Drive™ vs TranSynd®
Scroll down to the bottom of the page for the Comparison.
How does Torque-Drive™ compare to AMSOIL Synthetic Transmission Fluid (ATF)?
Torque-Drive™
was created to satisfy the concerns of customers currently using TranSynd®, and it carries with it the confidence to be used for the intervals established by Allison. AMSOIL ATF is a more advanced product with universal applications such as Mercon V and ATF +4. AMSOILdoes not recommend draining or switching to Torque-Drive™unless the Allison customer intends on following the extended drain interval recommendations of Allison.
Chris Kelley
Email
1-888-563-5143
