Old 02-12-2009, 06:58 PM   eBay Motors   #21 (permalink)
Duckman
Duckman's Avatar
I changed to Torque-Drive the other day , i dropped the valve body and cooler lines , let it sit overnight and from what i looked up on total capacity, i got it all out with this method.
I assume the converter drained 90% + ...with how much it took to refill . Also , there was nothing to prevent otherwise with the valve body out .
Just a FYI if anyone wanted to change over completely and does not want to waste it trying to flush with it or use one of those fluid exchangers.
02 LB7
4" down pipe back exhaust
ported intake horn
S & B filter
35" tires
performancetruckproducts.com/
Duckman is offline   Reply With Quote
Old 11-03-2009, 11:45 PM   eBay Motors   #22 (permalink)
45Colt45
45Colt45's Avatar
Just an FYI, I pulled this off of the Allison website:
Q. Automatic Transmission Fluid (ATF) - Can I use synthetic fluid?
A. Any fluid that meets DEXRON III requirements is suitable for use in the Allison 1000 Series™. Always verify that the container reads DEXRON III, regardless of whether it is mineral-based or synthetic.
Back To Top
Q. Automatic Transmission Fluid (ATF) - Can I use TranSynd fluid?
A. TranSynd is a fully synthetic transmission fluid available from Allison Distributors/Dealers or at GM dealers. TranSynd is a licensed DEXRON III product and has been extensively tested by Allison Engineering in a broad range of Allison products. While TranSynd was developed mainly to meet the harsh operating conditions of heavy-duty transmissions in severe operating conditions like transit buses, its benefits translate to the pickup truck market.
Back To Top
Q. Automatic Transmission Fluid (ATF) - What type of Transmission fluid can I use?
A. Transmission fluids licensed by General Motors to use the trademark DEXRON III are required in the Allison 1000 Series™ transmission.
2002 Chevy crew cab short box LT package and Auto Trans. Truck is completely stock, but looking to change that soon!
2002 Chevy Camaro SS "35th anniversary edition"
2005 Chevy Avalanche
1988 20' Weldcraft Jetboat
1965 Malibu SS
45Colt45 is offline   Reply With Quote
