Old 02-12-2009, 06:39 AM   eBay Motors   #1 (permalink)
lastcall190
Trans Fluid...
I was going to drain the pan and change the spin on this weekend. I was going to use the Amsoil ATF fluid (not the TES-295 Torque Drive...) because I believe there is a Dex6 in there right now. Can I mix and match if need be? Meaning, can I use Torque Drive with what's in there with no adverse effect? I should need ~8qts, right? Thanks. Did a ton of searching but nothing came up in terms of mix and match.
-J
2006 LLY EC/SB
MBRP 4" Turbo Back
PCV Reroute
EGR Blocked
lastcall190 is offline   Reply With Quote
Old 02-12-2009, 12:10 PM   eBay Motors   #2 (permalink)
High Voltage
High Voltage's Avatar
Torque Drive is not compatible with DERON VI
2008 GMC Sierra Ex Cab 2500HD 6.6L LMM Z71
Edge juice W/ Attitude
Skyjacker front level kit
Boss Power VXT Plow
Lubed by AMSOIL
High Voltage is offline   Reply With Quote
Old 02-12-2009, 12:14 PM   eBay Motors   #3 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
so what fluid comes in the tranny from the factory?
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is offline   Reply With Quote
Old 02-12-2009, 12:24 PM   eBay Motors   #4 (permalink)
Dynaguy03
Dynaguy03's Avatar
i know my 07 lbz classic comes with dextron vI .. I did spin on and dropped the pan i think it was in the neiborhood of 11-12 qts
2007 Sierra Classic SLT 2500H.D. LBZ SHORTBED, EDGE INSIGHT w Pyro..(Meyer Performance -Tyler) PPE Standard..(Performance truck products-Nate) 4in MBRP SS CAT BACK ,5IN SLASH TIP, XDI TRU FLOW COLD AIR INTAKE,Drawtite Ultra Frame, Westin SS steps, Lund stone deflector and window shades, Sirius S50, Garmin GPS, Xtang Trifecta bed cover. If your in NJ never bring your GMC product to Flemington GMC.. just ask me why!
Dynaguy03 is offline   Reply With Quote
Old 02-12-2009, 12:26 PM   eBay Motors   #5 (permalink)
DuramaxSMOKE11
yea i think the 6speed uses different tranny fluid than the 5 speeds do
To come soon
Old 02-12-2009, 12:26 PM   eBay Motors   #6 (permalink)
Dynaguy03
Dynaguy03's Avatar
Actually its hard to judge i used amsoil ..disconnected the trans cooler lines and let the system pump out as i was adding.. its a wasteful messy operation..but i wanted to get as much of the old out as i could
Old 02-12-2009, 12:42 PM   eBay Motors   #7 (permalink)
High Voltage
2006 Allison came with Dexron III. They started using Dexron VI on '07. You can use III or IV in anything that takes III but you can not use III in a transmission that takes VI. I hope this helps out.
Boss Power VXT Plow
Lubed by AMSOIL
Old 02-12-2009, 01:36 PM   eBay Motors   #8 (permalink)
Dirtbikindad393
Your #1 Source For Amsoil
Dirtbikindad393's Avatar
Amsoil Universal ATF is comapatable with Dex III or VI.
Amsoil Torque Drive is not as stated above by High Voltage.
MadJack Racing & Synthetics
MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
Dirtbikindad393 is offline   Reply With Quote
Old 02-12-2009, 01:41 PM   eBay Motors   #9 (permalink)
Dynaguy03
Dynaguy03's Avatar
Yeah...What dirtbik said!!.. i noticed that was stated on the Amsoil Univ ATF container FWIW
Old 02-12-2009, 02:24 PM   eBay Motors   #10 (permalink)
High Voltage
Yes AMSOIL ATF covers many applications
Boss Power VXT Plow
Lubed by AMSOIL
