Old 02-23-2009, 06:59 PM   eBay Motors   #1 (permalink)
oleblacky
oleblacky's Avatar
Transgo Jr.?
What all does the Transgo do. The technician that works on my truck from time to time at the dealership asked me why I wanted to put the shift kit in if I am going to buy efi live. He said that you can turn the line pressure up with the programmer and I would just be wastin my money if I bought the shift kit. So is he right or is he just talking sh#*
Thanks
Brad
2006 Silverado LT Crew Cab
Durmax LLY Allison/6speed
Straight Piped Kitty Ran Off
Resinator Plugged PCV Reroute
Transgo Jr.
285/75/16 M/T wheels
Work Truck 08 LT LMM
Summit White Crew Cab
Bone Stock
oleblacky is offline   Reply With Quote
Old 02-23-2009, 07:02 PM   eBay Motors   #2 (permalink)
delong_1
truck for sale
delong_1's Avatar
he is full of it, do the transgo. it will help hold the power tuning cannot
Nate
2 turbos, built trans, and some tuning.
Old 02-23-2009, 07:03 PM   eBay Motors   #3 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
Nothing takes the place of a shift kit. When you do a trans go it increases the line pressure by making the ports bigger and the actuators on the solenoid valves bigger.I would ask if you can handle more power withthe trans go and the Efi live program.
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES
WORK RIG
DPF GONE!!!QUADZILLA STEALTH II, K&N FILTER, MAF CLEANER IN BED
This is not only your forum you have to share it with 27,000 others
Old 02-23-2009, 07:14 PM   eBay Motors   #4 (permalink)
FH Leader
FH Leader's Avatar
buy the transgo!
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
My iron is yellow
Id rather be dead then CUMMINS RED!
FH Leader is offline   Reply With Quote
Old 02-23-2009, 07:18 PM   eBay Motors   #5 (permalink)
Ridin'GMC
Ridin'GMC's Avatar
Get the transgo JR. I'm planning to do mine this spring. It will help to hold about another 20 hp so you will be able to hold 120 hp than 90 to be safe. I'm also going the EFI live route too. Where did you get the transgo Jr from?
06 LLY CCSB
Just another white truck on the site.
Tuned by Killerbee's Original LBZ tune.
Ridin'GMC is offline   Reply With Quote
Old 02-23-2009, 07:22 PM   eBay Motors   #6 (permalink)
diesel rookie
diesel rookie's Avatar
How hard do they shift after the transgo i'm also thinking about one!
05' GMC crew cab 2500HD D/A
4" MBRP Turbo back (lost the cat?)
BD Manifold
Autometer GS PYRO & Boost Overhead
PPE Standard Level 2 (save the tranny!)
KB IOH kit
Thanks to Tyler @ MPF and Nate @ PTP
diesel rookie is offline   Reply With Quote
Old 02-23-2009, 07:24 PM   eBay Motors   #7 (permalink)
Ridin'GMC
Ridin'GMC's Avatar
Sorry, transgo Jr only applies to the 6 speed tranny from 06 to current year. For the 5 speed, its not worth it because you have to remove the tranny to put the shift kit in. On the 6 speed, you just have to drop the pan and the valve body.
06 LLY CCSB
Old 02-23-2009, 09:23 PM   eBay Motors   #8 (permalink)
oleblacky
oleblacky's Avatar
Ok that's all I need to know fellas I appreciate it. Trans go it is.
Transgo Jr.
Bone Stock
Old 02-24-2009, 08:26 AM   eBay Motors   #9 (permalink)
jc1843
There is two TransGo kits-- one is the Jr. which was made for the six speed trans-- it includes two valve body trim valves with springs and balls-- you also have to drill two holes in the seperator plate to a larger size. This will fit and help a 5 speed trans somewhat, but not as much as it will for the 6 speed. Well worth it on all Allisons.
The other is a full TransGo (not Jr) and requires that you remove the trans and replace some inner parts.
Hope this helps. Jerry
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
