code p 1781 - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 03-13-2009, 08:57 PM Thread Starter
eslb7's Avatar
code p 1781
hello everyone i get this code once and a while when scanned it says manufacturer control transmission im just wondering what it is ive done a search here and theres a few different answers anybody know whats the real problem thanks
eslb7 is offline
post #2 of 20 (permalink) Old 03-13-2009, 09:01 PM
Chevyguy08's Avatar
P1781
4X4 Switch Out of Self Test Range
08 LMM is alive and well again with a few add ons
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
Chevyguy08 is offline
post #3 of 20 (permalink) Old 03-13-2009, 09:05 PM Thread Starter
eslb7's Avatar
ok what does that mean and how do i fix it any suggestions
eslb7 is offline
post #4 of 20 (permalink) Old 03-13-2009, 09:07 PM
Chevyguy08's Avatar
im looking to see what i can come up with for ya, one of tech specialists should be chime in here pretty quick
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
post #5 of 20 (permalink) Old 03-13-2009, 09:10 PM
Chevyguy08's Avatar
what the make and model of your truck and do you have anymods done to it?
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
post #6 of 20 (permalink) Old 03-13-2009, 09:14 PM Thread Starter
eslb7's Avatar
2001 chevy lb7 not yet but have a banks 6gun kit in shed waiting on good weather to install
eslb7 is offline
post #7 of 20 (permalink) Old 03-13-2009, 09:29 PM
Chevyguy08's Avatar
are you getting a check engine light, if you are at one times, just when you turn the key on, runnin down the road, or did you just check to see if you had codes
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
post #8 of 20 (permalink) Old 03-13-2009, 09:37 PM Thread Starter
eslb7's Avatar
every once and a while when it gets started the service engine soon light will come on and stay on sometimes for the rest of the day then when i run truck a few days later it wont be on other times i can start and shut of truck 50 times a day and its fine so i got it scanned a few times and thats the code ill get
eslb7 is offline
post #9 of 20 (permalink) Old 03-13-2009, 09:41 PM
Chevyguy08's Avatar
couple things to check, transfer case and front diff fluids, make sure no wires are bare or shorting together on either transfer case or front diff, just to eliminate the easy stuff first
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
post #10 of 20 (permalink) Old 03-13-2009, 09:43 PM
mijdirtyjeep's Avatar
I would also check the connectors at the ECM and TCM just to make sure they are secure and tight
Jim
mijdirtyjeep is offline
