Allison 1000 coolant line size - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 07-20-2013, 04:57 PM Thread Starter
willmonte72's Avatar
Does any one know the exact size of the coolant inlet and outlet on an allison 1000. im looking to replace my steel lines with braided so i have more reliable flexibility for coolers. (better flow, better cooler, better time )
2002 crew cab LB7/allison 1000 sleeper in progress
S475 over billet IHI, 45% exergy injectors, stock CP3 (trying to save the rods) Studs, y-bridge, built trans, t case, traction bars, fass 150 w/sump, tuned by Accel Diesel in Henderson Co. and bunch of other small goodies.
willmonte72 is offline
post #2 of 10 (permalink) Old 07-20-2013, 05:15 PM
Alligator already has a hydraulic hose kit their selling to fix this.
lowstroke23 is offline
post #3 of 10 (permalink) Old 07-20-2013, 05:48 PM Thread Starter
i found the kit for the 6-10 duramax on alligator but the lines are for a lbz and lmm factory cooler. and they wouldnt flow as much as braided, and are more expensive.
post #4 of 10 (permalink) Old 07-20-2013, 05:51 PM
TakeEm's Avatar
All season diesel sells a kit.
Sent from AutoGuide.com App
Caleb
2011 Denali LML
Wehrli Emissions Compliant 475/stock kit, Wehrli Dual CP3 Kit, Merchant Auto Trans, Fass Pump
Tuned by Duramaxtuner
Sold 7/2015: Twinned 07 LBZ
TakeEm is offline
post #5 of 10 (permalink) Old 07-20-2013, 05:54 PM
OregonDMAX's Avatar
i installed the Alligator trans cooler line kit and its a damn nice product if i do say so.
02 CCSB 4x4
Mike L trans, Magnaflow 5" straight pipe, Magnaflow 3" DP, AEM CAI, EFILive by Idaho Rob, ADII 165, BT lockup box, CTS Insight, boost increase valve, RDL intake horn, manifolds/uppipes, 3" MBRP boost tubes, port/polished/wetzel wheel turbo by Yellowchevy, turbo blanket, Rareparts HD tierods, Allseason brace, 3/5 drop, 60" traction bars, MA pumprub fix, Alligator trans cooler lines. Russell stainless brake lines, LML 20's/420's
OregonDMAX is offline
post #6 of 10 (permalink) Old 07-20-2013, 05:55 PM
OregonDMAX's Avatar
they have a kit for the 01-05 but you have to call, why do you need so much flow, they flow plenty its not going to make a difference
02 CCSB 4x4
post #7 of 10 (permalink) Old 07-20-2013, 05:57 PM
Whitemax2006's Avatar
Installed the alligator performance lines on my 6-speed, easy to do and you get rid of the rubber to metal GM crimps that always leak
Whitemax2006 is offline
post #8 of 10 (permalink) Old 07-20-2013, 06:01 PM Thread Starter
Im trying to get more flow because i drive my truck for up to 18 hrs a day constant, so im trying to get more fluid through the cooler faster to try and keep it from heating up at idle, stop go traffic, etc..... that and with braided lines i have more options of coolers. right now i have the ppe cooler and it keeps me at the 80-100 degree above ambient range, but if idle too long in traffic it heats up quick
post #9 of 10 (permalink) Old 07-20-2013, 06:06 PM
TakeEm's Avatar
The Allison will run 100 degrees over ambient.
I think your theory of flowing more with bigger/braided hoses, isn't helping you. A bigger cooler is going to help you.
Caleb
2011 Denali LML
TakeEm is offline
post #10 of 10 (permalink) Old 07-20-2013, 06:12 PM Thread Starter
yeah, thats one of the other reasons why i wanted to switch to braided. so that i can run a monster of a trans cooler in the grill with flexibility, or make it a ton easier to plumb up doubles. I considered mounting a cooler with a fan on the underside, but muddy roads, and snow arent the best for those lol
