Old 09-10-2009, 07:08 PM   eBay Motors   #11 (permalink)
Iowa Farmboy
Iowa Farmboy's Avatar
Could some one please explain what exactly is "stall speed"? I have always been confused. I'm stupid but does it mean that the truck under normal driving would not move until 2300 rpm for example. Creating a tire burning start every time. I'm sorry if this has been covered before but I have not found it using the search button.
2005 Chevy 2500 CC/SB 4x4 w/topper
Magnaflow 4" SS w/muffler down pipe back
Flex-a-Lite dual fan, KB turbo MP, True Flow air intake pipe w/factory paper filter & modified box w/homemade cold air.
285 BFG AT, Recon LED roof lights & Big Rig side lights
boost and egt in piller EFI Live
DOG BED IN THE TOPPER
Iowa Farmboy is offline   Reply With Quote
Old 09-11-2009, 08:37 AM   eBay Motors   #12 (permalink)
IdahoRob
IdahoRob's Avatar
Remember, those stall speeds posted are with stock tuning. Also the converters all react differently in different applications. At 700HP my street truck and a 1057 will stall well over 3000rpms.
Make sure to talk to someone that knows how these converters work in your own application.
2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 09-11-2009, 08:40 AM   eBay Motors   #13 (permalink)
IdahoRob
IdahoRob's Avatar
With a diesel converter, they all will couple and move the truck at any thing off idle. These stall speeds are loosely definded by mashing the brakes and flooring the throttle and where the engine will hit a wall in rpms. HP has a huge effect on stall speeds though.
Old 09-11-2009, 10:17 AM   eBay Motors   #14 (permalink)
Duramax_JP
Originally Posted by MMLMM View Post
Ok this is all on the SC site, but I went thru it and grouped it all together to help people in need when shopping for a converter from SC. Hope it helps someone.
The Sun Coast diesel torque converters, designed and manufactured by Sun Coast, are engineered to improve the efficiency of your vehicle from off idle to maximum RPM. Sun Coast converters are designed to maximize the efficiency of a vehicles engine and torque converter combination to improve the acceleration and pulling power of your diesel truck. With the engine performance enhancements available for diesel engines, a more efficient and durable torque converter is required to optimize the vehicles performance.
Sun Coast torque converters include the latest in converter technology and are suitable for highly modified diesel engines. If your truck is used for towing (5th wheel travel trailer, horse or livestock trailer, boat or equipment trailer) the Sun Coast converter will vastly improve the performance and reliability of your truck. The Sun Coast converter features our multiple 3-disc clutch along with our billet steel cover to provide 3 times the torque capacity of the factory converter. Sun Coast does not use "one size fits all". Utilizing our billet "radial pull" stators, Sun Coast offers a converter specifically designed for your application. If you are looking for a combination of long service life, dependability, and performance, Sun Coast converters delivers.
Features:
Furnace Brazed Impeller
Torrington Needle Bearings
Precision Steel Pump Drive
Custom Stator
Multiple Disc Lock-Up Clutch
Billet Steel Cover
The Converters:
1054
Approx. brake stall is 1900 RPM
This converter is great for everyday driving with stock to medium size turbos and big HP tunes. It will brake stall at 1900 RPM, but still couples at cruising speeds. Shifts at 2000-2500 and you will see about a 500 RPM drop. This converter has no limits.
1055
Approx. brake stall is 2600 RPM
Our 1055-3D converter will let huge turbos spool and light. It allows great turbo spool-up and will couple well as a result of utilizing larger windows that offer the more efficient fluid flow . Our #55 IS NOT intended for towing, but if you insist you can, It has no limits. This was designed for drag/sled pulling trucks with XLarge turbos that need to spool.
1056
Approx. brake stall 2000 RPM
This is our journeyman converter that incorporates an OEM style stator and custom modified impeller to allow low end torque multiplication (" gets the load moving") and high end efficiency ("puts the power to the road"). Combined with the Sun Coast triple clutch and billet cover it is a great converter for daily driving, towing and or racing. This converter spools good with stock to medium size turbos.
1057
Approx. brake stall 1800 RPM
Our 1057-3D converter established a benchmark for performance torque converters. Often referred to as the “McRat” it has set numerous records at the strip since its’ inception in 2005. Our #57 series incorporates a modified OEM stator and is coupled with the "Velocity Series" impeller. It allows good turbo spool-up with stock size turbos running mild tunes and also offers more efficient fluid coupling than our #56 converter. If you’re running the larger turbos and the wild tunes and need to spool see our #55, #58 or #59 series converters.
1058
Approx. brake stall 2300 RPM
This converter is great for everyday driving with stock to medium size turbos and big HP tunes. It will brake stall at 2300 RPM, but still couples at cruising speeds. Shifts at 2000-2500 and you will see about a 500 RPM drop. This converter has no limits.
Notes:
New for 2008 are our custom designed billet stator series #54, #55, #58 and #59.
Larger turbos may need our #55 or #58 converters.
With the addition of the 1055, 1058 and 1059 to our Allison torque converter line we can accommodate any request in regard to stall, torque multiplication, efficiency, or other custom application. The stall test and RPM drops were tested with Stage V transmission, stock turbo with a 350HP tune, stock size tires in our 3500 dually. The example stalls and RPM drops are strictly to help you decide which may be best for your truck. Big tires without gear swaps will raise your brake stall test numbers.
Again, this is directly from there site. I am no way affiliated with SC. I run there product and have had good luck with it. I am posting this for information to the forum for quick reference.
1059?
I wasnt aware there was a 1059 or did I read wrong?
2006 CCSB 4x4 LBZ
MODS: EFI LIVE-MITUSA LIFT PUMP-DIAMOND EYE DP-BD MANIFOLD-5" STRAIGHT PIPE-PACBRAKE SLEEVES-BANKS RAM AIR INTAKE-TRACTION BARS (BUILT BY DMAX15)-DI PROCOL PYRO, BOOST, AND DP
KICKER CVT 10" SUBS
PIONEER D3 NAV
Duramax_JP is offline   Reply With Quote
Old 09-11-2009, 09:42 PM   eBay Motors   #15 (permalink)
IdahoRob
IdahoRob's Avatar
1059 has really never been out(just a couple). Was supposed to be for twins.
There is a brand new one in testing right now that looks promising.
Old 09-11-2009, 11:35 PM   eBay Motors   #16 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
tahnk u that finally helped me pick which t/c im gettin thank thank u
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
Old 09-12-2009, 12:50 PM   eBay Motors   #17 (permalink)
HumboldtDmax
Obama stole my rims
HumboldtDmax's Avatar
So what is the brake stall of our stock TC so we have something to compare to?
7.5 LMM CHEVY CC LT Z71 white
Fab Four front bumper, lots of Line-X
Rancho 4in w/Bilstiens, HD tie rods and braces
35x12.5 Toyo MT on 20x10x4.5BS KMC Monsters in black
[BANKS intake,dual exhaust,intercooler]straight piped
BD manifold,Fitch fuel catalyst,res mod,EGR delete
AFE turbo tube, PPE race fuel valve
EFI live, Edge Insight
AD150 & SC4 collecting dust in the shop
HumboldtDmax is offline   Reply With Quote
Old 09-13-2009, 04:32 PM   eBay Motors   #18 (permalink)
couchj317
couchj317's Avatar
The Converters:
1054
What does this 500 rpm drom refer to? lower rpms at cruising speeds, different shift points, lock up speed, or what?
2004.5 LLY: MBRP Turbo back 4" with 5" chrome tip, PPE Excellerator standard level 3 for now, LBZ turbo inlet tube (mouthpiece), Hook em Horns CAI mod plus my own addition of foam under the airbox and between the airbox and the coolant reservoir, EGR Blocker plate, Autometer digital EGT, and Boost gauge. Windows tinted 9% front 5% rear windows, Vent shades, Husky liner floor mats(awesome), B & W turn over ball goosneck hitch.
Ordered Transparts stage 3 and Precision ML conveter
Bearded Dragons for Sale | breeders
couchj317 is offline   Reply With Quote
Old 10-08-2009, 02:33 PM   eBay Motors   #19 (permalink)
gya0ma7ha
gya0ma7ha's Avatar
I think it is referring to how engine much the engine rpm will drop when the converter locks. Lets say your accelerating, easily, and your converter decides to lock, your rpm will go from lets say 2000 to 1500, while you are accelerating.
But i am not sure, just assuming, and we know what happens when we assume haha.
2001 2500HD LT CCSB 4X4 LB7 TAPE DECK INCLUDED
Autometer Cobalt Boost and Pyro, HID headlights/fogs, 05' Tailights, De-Badged, Some sound stuff
35" Wrangler DuraTracs on KMC 20" Rockstars and a 6" procomp drop knuckle and black runners.
EFILive
Modded intake horn Banks Big Head, banks CAI, banks straight pipe
Need List: CP3!!!! Wish List: Transparts iv, Lift pump, Turbo upgrade.
Sports: Motocross, football, golf, lacrosse
They call me "G-Money"
gya0ma7ha is online now   Reply With Quote
