Transgo is def. worth it...read my sig!! You would rather a trans shop install it or study uop yourself and take your time, do it right. Not that bad, just be patient and meticulous with your work. Fortunately, I do lots of work on trans pans and filters, so not much was new to me when I did mine. Your shifts will be firmer and more positive, you will enjou it...vendors on here sell it so buy from them....Jason
__________________ 2006 2500 LBZ CREW CAB LONG BED * NFAB STEP BARS
35" TOYO OC MT"S W/ 18" ROCKSTARS * FABTECH 6" LIFT * FABTECH HD TIE RODS
BD FULL BORE MANIFOLD * S&B CAI
4" STRAIGHT PIPE EXHAUST * MBRP 5" TIP
TRANSGO JR 4/11/09...THIS WAS A GREAT MOD!!!
BANKS INTERCOOLER * RESONATOR HOLE PLUGGED
EGR BLOCKER PLATE * EDGE INSIGHT MONITOR TUNED WITH EFI LIVE>>>NOTICE I AM SMILING!!!! www.performancetruckproducts.com www.huskerdiesel.com
__________________ 07 Chevy Classic LBZ CC SB 4x4
PPE standard
Transgo jr
AFE Stage II
MBRP 4 inch cat-back exhaust
Ready-Lift leveling kit with 315's
Warn brushguard with Powerplant 12,000 lb winch FOR WHEELS AND TIRES VISIT: www. dicounttiredirect.com www.huskerdiesel.com www.performancetruckproducts.com
yes, IMHO, it does help the trans shift smoother and it holds a bit more power. ask me how I know!:cool
__________________ Dallas Crist
2006 Chevy 2500 HD LBZ RCLB 4x4
6" BLACK stack; CAI; PPE Lift Pump; PCV Reroute; PPE Tie Rod Sleeves; EGR Block Plate; TransGo Jr.; Stanadyne Performance; Amsoil;
Best 1/4 13.41@102.8 (early summer '09); Best 1/8 8.09@87 (Fall '09)
EFILive by Husker Diesel: name that tune--DallasCleanHotv.1
Got Cheese? Work RAT!
the JR kit increases line pressure and will help the life of the clutches. So, yes, it will "protect" and lengthen the life of your trans. Its a "must have" on the 06+ Duramax.
All has to do with Trim valves. Trim valves in an Allison trans perform the same function as an accumulator in another transmissions, lets the valves react quicker. If you want to get more pressure you have to go to the main regulator valve, shim it and that ups the pressure (basic hydraulics)
trust me this will be the best money you will spend on your truck jess @ husker diesel hooked me up with one and it made a world of difference with shifts best mod for the money imo on the 6 speeds
