Old 07-31-2009, 10:48 AM   eBay Motors   #1 (permalink)
jscribn1
jscribn1's Avatar
Trans fluid?
I have an 06 LBZ and it's time for the tranny service. I can't get a straight answer from GM on my fluid type. I want to do the deep pan conversion and do the TransSynd fluid. Will I be ok doing this if I don't have TransSynd in it now? Any other recomendations? Thanks
jscribn1 is offline   Reply With Quote
Old 07-31-2009, 10:56 AM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
Dextron VI.
Old 07-31-2009, 11:20 AM   eBay Motors   #3 (permalink)
JoshH
Yes, you can change it to TranSynd without hurting anything.
06 2500HD Silverado CC/SB 4x4
Still a few stock parts left...
JoshH is offline   Reply With Quote
Old 07-31-2009, 11:41 AM   eBay Motors   #4 (permalink)
jscribn1
jscribn1's Avatar
Originally Posted by Hondarider552 View Post
Dextron VI.
Do I have Dextron VI in there now? Will I benefit from the TranSynd? I pull a 40' toyhauler and want my tranny to last. Thanks for the help.
Old 07-31-2009, 11:52 AM   eBay Motors   #5 (permalink)
JoshH
Stock fill is Dexron VI. Yes, you will benefit from changing it to TranSynd.
Old 07-31-2009, 11:58 AM   eBay Motors   #6 (permalink)
palposity
palposity's Avatar
I've been using Amsoil Torque drive....I pull heavy loads of stone, dirt, and construction materials. I've been very pleased with it's performance.
2001 Silverado CCSB 129K Miles
bigdaddydiesel for all your Synthetic fluid needs
palposity is offline   Reply With Quote
Old 07-31-2009, 12:33 PM   eBay Motors   #7 (permalink)
pONSi
pONSi's Avatar
i recently switched over to Transynd...I just drained the Dex VI from the drain plug and added about 10.5 quarts of Transynd with an Allison deep pan
'06 LBZ
Duramax Allison Transmission
EFILive (stock tuned for now), MBRP duals
pONSi is offline   Reply With Quote
Old 07-31-2009, 01:24 PM   eBay Motors   #8 (permalink)
jscribn1
jscribn1's Avatar
I just ordered my fluid from the Dmax store. I got the 3 gallons of fluid, deep pan and filter, the external spin on and a fuel filter for $290 shipped. I called and left a message for them and Mike called back within 10 minutes and gave me all the advice I needed. They are A++ in my book. Thanks for all the help.
Old 11-03-2009, 11:41 PM   eBay Motors   #9 (permalink)
45Colt45
45Colt45's Avatar
So I know I am a newer member but I see that this is somewhat of a heated discussion about what fluid to use in the transmission. I was about to change mine today and held off so I could get more information. I would like to hear more from HondaRider552, because he is very set in the Dextron VI, which is what GM recommends (and it is a synthetic), but why are you so devoted to dextron, as apposed to transynd, or any other fluid?
ALSO: I went hunting for more information, this is directly from Allison, they reccomend any DextronIII or better fliud, but are VERY BIG on the transynd:
Q. Automatic Transmission Fluid (ATF) - Can I use synthetic fluid?
A. Any fluid that meets DEXRON III requirements is suitable for use in the Allison 1000 Series™. Always verify that the container reads DEXRON III, regardless of whether it is mineral-based or synthetic.
Back To Top
Q. Automatic Transmission Fluid (ATF) - Can I use TranSynd fluid?
A. TranSynd is a fully synthetic transmission fluid available from Allison Distributors/Dealers or at GM dealers. TranSynd is a licensed DEXRON III product and has been extensively tested by Allison Engineering in a broad range of Allison products. While TranSynd was developed mainly to meet the harsh operating conditions of heavy-duty transmissions in severe operating conditions like transit buses, its benefits translate to the pickup truck market.
Back To Top
Q. Automatic Transmission Fluid (ATF) - What type of Transmission fluid can I use?
A. Transmission fluids licensed by General Motors to use the trademark DEXRON III are required in the Allison 1000 Series™ transmission.
2002 Chevy crew cab short box LT package and Auto Trans. Truck is completely stock, but looking to change that soon!
2002 Chevy Camaro SS "35th anniversary edition"
2005 Chevy Avalanche
1988 20' Weldcraft Jetboat
1965 Malibu SS
45Colt45 is offline   Reply With Quote
Old 11-04-2009, 08:29 AM   eBay Motors   #10 (permalink)
JuniorDiesel
JuniorDiesel's Avatar
I would recommend sending a PM to bigdaddydiesel, mrmanners, or chevy*tough and ask how Amsoil Torque drive can help you.
Amsoil torque drive meets or exceeds all manufactures specifications and is great stuff!!
2007.5 Silverado 2500HD LMM
Edge Evo CTS
MBRP 4" DPF back exhaust, H.I.Ds, Billstien 5100's ON THE WAY
AMSOIL
http://www.lb7.info/
http://www.syntheticmotorsports.org/
Toys:
2008 38' Heartland Cyclone Toyhauler
2008 Raptor 700R - FCI intake, DRD exhaust, PCV
JuniorDiesel is offline   Reply With Quote
